Hi,
I have been searching to find if a USB to IEEE 1394 4 pin cable I have will work in connecting a Samsung VP-D361i Digital Camcorder to my PC to transfer video for editing and burning via the DV port.
I have connected it to the cable & PC and I get an error saying device is malfunctioning or not recognised. I went to the Samsung site and loaded the driver which did nothing. Not sure if I need more drivers for firewire or if it will never work and I should pruchase a IEEE 1394 card and cable.
Appreciate some advice.
You tried connecting it directly via firewire? or your having problems with the USB?
Whatever the case you need to use firewire, USB for most cams is a low quality video and not a direct transfer like firewire. -
I do not have firewire but some sites say you can use USB2 to transfer with this cable. I thought I might not have the right drivers?
It will tansfer video but again its low quality. If it transfers the full DV quality over USB than you have a rare model on your hands. Some pro cams have this feature but I'm not aware of any consumer models that work over USB .
Note that the USB is also for tansferring still images from a memory card if it has that feature.
As far as a combo cable I really have no idea but my guess is that the brick wall is going to be the software. I'd also imagine you are going to lose the ability to control the cam and other things. Save yourself some grief and get a firewire card and cable. Plug and play.... -
There is no statement in the promotional literature about USB DV format transfer. Did you find anything like that in the manual?Originally Posted by antonyl
http://www.samsung.com/au/products/videocamera/digitalvideocamera/images/VP_D361inew.pdf
If you did have one of the rare models with USB DV transfer it would require special software from Samsung to get the DV-AVI file into the camcorder. Then you would import the file into your edit program. The edit program won't see or control the camcorder through USB except maybe as a digital camera (stills, webcam formats).
My IEEE 1394 cable can't be detected
By edhani in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2011, 08:19 -
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 05:28 -
IEEE 1394/MS DV ERROR
By sampatman in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 11:54 -
Will this cable work to connect my Epson S3 VGA port to aHDMI DVD recorder?
By NG in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2007, 00:20 -
is the IEEE 1394 Adapter port necessary...
By roochie in forum MediaReplies: 15Last Post: 15th May 2007, 20:03
