After I'm adding the Mpeg the program wants the VFAPI-AVI file
to create the menu .
what is it? do I need it to meke menu's? how can I make it?![]()
i dont think that is needed.
if you want to make one youd meed the vfapi plugin. taka a look in the tools section you might find it there.
it asks for the vfapi file for menu creation in TSCV. it makes the searshing faster and better i think. If you already have the BMPs you want to use for the menu you dont need that. (i dont use it)
hope it helpsWell, I am the slime from your video.
Oozin' along on your livin'room floor.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
