Hi,
I have downloaded and installed Super v.2007.build.22 with no problems at all except that I can not see all of the menu for it? mainly the very bottom of the screen with the Encode Buttons,etc... I can tell they are there as I can just barely see the top of the buttons.
It doesn't matter what Screen Resolution I use either its the same no matter what.
Does any body know how I can fix this?
I have attached a screen shot of the buttons I cant see(they are in the red box).
Thank You
LCE
Set your desktop to a resolution higher than 800x600 and reboot.
The SUPER developers don't seem to want to budge on that point - it requires your desktop to be at least 1024x768 to run properly, I believe.If cameras add ten pounds, why would people want to eat them? -
Hi Ai Haibara,
That was it. I had changed resolutions but did not reboot so I wasn't seeing any change on the program.
I Appreciate the help
LCE -
Hello AI-chan
im trying using the SUPER on my pc to convert an AVI file that i donwloaded from torrents, after finishing the job. it only had sound no frame when i playing the converted file.
whats happend? is it not compatible with the codec or the SUPER it self had problem?
thanks -
use gspot on your source, to make sure what it is ?
also make sure you did NOT accidentally check the 'disable video' box
if you do , there will be NO video stream
super's codecs are built in, but your player may not be compatible with what you converted too
you did not give us your source specs, res, bit rate , codec encoding container etc..
or the output specs you converted too -
C-W: Does the original AVI play properly in whatever player you're using? SUPER doesn't produce any errors when converting the file? What did you convert the AVI to (in other words, what settings did you use)?
You might run the original AVI, and maybe the resulting video, through a utility like GSpot and post the screenshots of the results here. Blank out the filename/path information if you prefer.
(Also, SUPER can provide 'detailed' information as well - double-click on any file in the job list, and it'll pop up an information window. But it's probably easier just to use GSpot than load SUPER, if all you're going to do is get information on the files.
SUPER v2011 Build 48 Contains a Trojan !!!
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2011, 16:19 -
Does anyone still have the older build of SUPER?!
By Nintendo Fan in forum Video ConversionReplies: 11Last Post: 21st Jan 2009, 19:29 -
Super Build 35 - does deinterlacing work?
By dvdfever in forum Video ConversionReplies: 0Last Post: 7th Jan 2009, 04:22 -
SUPER v2007.build.22 (Mar 14, 2007)... does anyone have it?
By jamescardenas07 in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 23:10 -
Super c vr 2007 converter
By theness in forum Video ConversionReplies: 2Last Post: 25th May 2007, 13:58
