Has anyone had any success creating a music dvd of more than 99 music files. If so, what software did you use and how many music files did you include plus any other tips?
Or....if someone has any advice for my DVDLabPro problem.
In DVDLabPro I tried creating 3 VTS's and dividing 221 music files [AC3s] between 38 menus with 221 movies [one AC3 per movie].
Theoretically, DVDLabPro is supposed to be able to do this, but after creating only 45 menus, I'm getting error messages....
"failed to create empty document" .....and then I can't create any more menus.
Then I tried creating more VTSs with only 6 menus per VTS and after only 56 menus....same problem.
I've read the "How To" guides below, but at this point, they're not helping me.
https://forum.videohelp.com/viewtopic.php?t=287574
https://forum.videohelp.com/viewtopic.php?t=300631
I hope this is clear. Thank you
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
borax
GfD in MuxMan mode sounds encouraging. Does the standard free version work just as well for what I want to do or is it better to buy the higher version?
Also, do you know of any help file that is oriented specific to creating music DVDs?
I may need a little boost since I can't even get the software to load or even recognize my AC3 files.
Thanks again for the suggestion -
The freeware version is enough.
...I can't even get the software to load
Have you installed GfD as 'full install'?
What happens if you start GfD?
...help file that is oriented specific to creating music DVDs
No, not really. But it isn't that complicated.
This page may be helpful for you:
http://download.videohelp.com/gfd/Help/AudioTitleset.html
For the menus, set up a suitable grid and use the 'Grid menu layout':
http://download.videohelp.com/gfd/Help/GridMenuLayout.html
If you need more help, just ask againGUI for dvdauthor:
guns1inger
It is the latest version and I found the Mega Project Option. I never knew what that was....thank you
Borax
The problem was not knowing what to do after inserting the Audio Titles Set Option. This time, thanks to your HELP links, I knew what to do with the Crosshair. I may have more questions of which I'll open a new thread, if and when. Thank you
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 18:56 -
Joined MTS files from Panasonic HDC-SD70, create audio delay...
By pleindepuces in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Dec 2010, 16:29 -
IVR video files, how to create DVD from them
By 1234567 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 22:58 -
Here is how to create PS3 Compatible Files with 5.1 Audio
By pogues in forum MacReplies: 1Last Post: 5th Jan 2009, 01:30 -
How would I create an Audio DVD from my audio files from scratch???
By Hittz in forum AudioReplies: 6Last Post: 10th Jun 2007, 04:15
