Subtitle Workshop freezes when loading an Mpeg2 program file (video and audio). This does not happen when loading an Mpeg2 elementary file (only video). Therefore I have to demux my movies before adding subtitles and it becomes very difficult to synchronize the subtitles with the video when thereīs no sound. Does anybody know a solution to this. I use the latest version of Subtitle Workshop.
does the mpeg2 file work with windows media player without any problems?
Maybe you can try install another mpeg2 decoder and see if it works better with subtitle workshop. You can check what mpeg2/dvd codec that is the default with the Windows XP Video Decoder Checkup Utility , http://www.microsoft.com/downloads/details.aspx?familyid=de1491ac-0ab6-4990-943d-627e6...displaylang=en
Or maybe it's enough with ffdshow or ac3filter to decode the audio. -
The muxed file also causes windows media player to freeze, the demuxed not. The muxed file is playable with PowerDVD, Nero Showtime as well as the editors from Womble and Videoredo.
I have the following mpeg decoders on my system: Elecard, AVS, Nero, Mainconcept, Cyberlink, Ulead and Intervideo. None of them are accepted as compatible with windows media player 10 according to the video decoder checkup utility and only the Nero decoder is reported as compatible with MCE ( I have XP pro). However I couldn't see which decoder was the default so I selected Nero. The audio in the muxed file is 2 channel Mpeg, the ac3filter is already on my system and I dont know ffdshow or how to use it. -
I solved the problem by installing the latest Elecard Mpeg2 decoder package. The current installed one was obviously outdated.
Keeping subtitles in 2 lines from original .txt file in Subtitle Workshop
By Valerc in forum SubtitleReplies: 3Last Post: 10th Feb 2012, 06:45 -
subtitle workshop crashes when loading video
By stem300 in forum SubtitleReplies: 0Last Post: 29th Dec 2011, 15:37 -
Subtitle Workshop crashes upon loading subs
By mystic818 in forum SubtitleReplies: 9Last Post: 17th Mar 2011, 06:51 -
IMporting to Subtitle Workshop from txt file
By kouim in forum SubtitleReplies: 4Last Post: 27th Jan 2011, 16:26 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 06:57
