I am trying my best to learn about AviSynth scripts and cannot find out how to add them right like I want to adjust contrast in my script or gamma what line do i add as it seems hard at 1st unless there is a program which adds lines like cont and others automaticially i have heard of one but lost name of it now
# -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =-
AVISource("G:\movie.avi")
LanczosResize(688,528,6,0,548,288)
AddBorders(16,24,16,24)
AssumeFPS(25.000, true)
#Trim(0,162624).FadeOut(150)
AVSEdit is a pretty good editor, as is AvsP. AvsP also allows you to set up interactive sliders so you can see the changes you are making as they happen. AVSEdit also comes with a self-contained version of the Avisynth help documentation as well as covering some of the better external plugins. Very handy as a quick look-up.
In your specific case, you probably want to use the Tweak statement, and you want to add it between the Resize and the AddBorders statements. That way the borders won't be affected by any changes you make. try either
Tweak (Cont=1.0), then change the value to adjust the contrast.Read my blog here.
Respect to you for going through the learning curve. Once you figure it out, you'll always use it.
http://avisynth.org/index.php?page=Tweak -
Here's your previous thread about it:
https://forum.videohelp.com/viewtopic.php?t=327761
When you lose track of one of your threads, hit "Advanced Search" at the top of any thread and search on your name. -
yeah sorry but i did lose thread thanks
anyway on that tweak page what do all this means
Tweak(clip clip [, float hue] [, float sat] [, float bright] [, float cont] [, bool coring] [, int startHue] [, int endHue] [, int maxSat] [, int minSat] [, int interp])
and where is command to sharpen -
It means you can string together the Contrast, Brightness, Hue, and Saturate and Coring commands in the same Tweak. Like I showed in your other thread:
Sharpen is a different filter:Tweak(Bright=20,Sat=30,Coring=True)#Coring is on by default
http://avisynth.org/index.php?page=Blur
It's a pretty lousy sharpen filter, though. There are better ones, once you learn some AviSynth:
http://avisynth.org/LimitedSharpen -
sorry to be a bit unsure of this but what do they mean by Sharpen(clip clip, float amount)
whats this clip,clip and what amount do you put -
The clip is there in case I want to load several clips and only one will be sharpen.
For example:
a=Avisource(\blah.avi)
b=Mpeg2source(\blah.d2v)
c=avisource(\blah-blah.avi)
Sharpen(c, 1.234567)
You see I am loading three videos, give them names (a,b and c) and try to sharp only the third. Now the amount of sharpening is float (not integer).
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 09:29 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 22:37 -
Avisynth Script Help
By jamhat in forum Video ConversionReplies: 2Last Post: 29th Nov 2009, 07:13 -
Avisynth script
By daz2712 in forum Video ConversionReplies: 2Last Post: 19th Aug 2009, 12:08 -
avisynth script
By magenta2007 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Sep 2007, 12:29
