DVD Shrink has been around quite a while, but IMO, there's no better freeware tool for backing up your own DVDs.
If you use RipIt4Me or DVDFab Decrypter before using Shrink, it will work with most any DVD, even the newer ones with Sony ARccOS encyption.
If you are using the program, here's a few improvements you might look into. http://www.dvdshrink.info/index.php Take a look in the 'Goodies' section.
You can set Shrink to automatically start up when you insert a DVD and you can change the icons in the program to something a little newer. Also, if you want to set ImgBurn for the default burning program, (Highly recommended) here's a way: http://forum.digital-digest.com/showthread.php?t=55859
These mods also work with Vista.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
