Premiere Pro 2.0 now works under Vista with the new Catalysts (7.3) so I decided to not reinstall XP and give this one more try...
I'm trying to encode some Fraps movies to Xvid but the encoder seem to crash when I export. Also, I have no idea which audio compressor to use (AC3 crashes) so I dunno... Is there a way to make web-compatible movies with this OS ????
Try VirtualDub - it encodes to Xvid and also compresses audio too (but probably not to AC3).
If you want AC3, use ffmpeggui then combine the audio to the video.
VirtualDubMod is also an option - I prefer the way it works with audio streams.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Any good suggestions on what to export my Premiere project as ? Should I use some kind of lossless codec and then work that with virtualdub ?
Also, what audio compression should I be using for good size/compatibility (it's for web content). -
Fraps "movies" are, from my exerience, captured to uncompressed AVI. Also, from my experience, exporting from Premiere Pro to Xvid can be troublesome.Originally Posted by bledking
So a "good" suggestion would be...
Take your AVIs from Fraps straight into VirtualDub.Originally Posted by daamonThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Question about settings for convert movies in divx/xvid to m4v or mp4
By Marcelo_Ramone in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2011, 10:25 -
Colorspace loss when converting from FRAPS to XviD?
By Foxhack in forum Newbie / General discussionsReplies: 16Last Post: 25th Aug 2011, 19:19 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
