I have an divx avi file with 2 audio files in it. How can I seperate the audio and the video files without having any quality loss in the audio or the video?
Try opening it in VirtualDubMod, then click Streams -> Stream List. Hopefully, it'll list both audio streams there.
From there, you select the one you want and "Save WAV". Note: This will save the audio, whatever the codec used, to a file with a .WAV extension (ending) but it doesn't mean it's a WAV file. You may need to change the extension.
e.g. if the original audio was MP3, then change WAV to MP3.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I would suggest you select Demux. The solely reason is some apps don't like mp3 (or ac3 or whatever it is) with WAV header.
Originally Posted by Abond
However, I've since tried "Demux" on an Xvid AVI with CBR MP3 and I got a perfectly playable MP3 audio file out.
So, yes, "Demux" is the way to go and "Save as WAV" as a backup.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Question about audio when ripping DVD to AVI file
By joylamyy in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2011, 14:56 -
[Question] How to insert an SRT (Subtitle) file into an AVI file?
By Greg14 in forum SubtitleReplies: 5Last Post: 30th May 2009, 04:54 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
