Just a quick question
I have just produced my first DVD, its works, yay etc
However, I have totally forgotten how to put multiple DVD compliant files onto one DVD using GUI for DVD author (I used this program to do my first single file DVD)
I have a guide for DVDAuthorGUI, but the point is, I want to learn how to do it with GUI for DVD Author too, yes a bit obsessive I know
If anyone can help, I really would like to crack on with this ASAP
cheers![]()
Ok, I now appear to have a video TS folder with my authored files
Is there any way I can watch it (in a similar way to mounting images in Daemon Tools) to check it functions properly prior to burning the final disc?
I am not sure which image software I require
Cheers
I'v got a couple of DVDRWs that I use to test things like that. No wasted coasters if it fails.
Where is a windows-installer of LibreOffice at the moment?
By flashandpan007 in forum ComputerReplies: 13Last Post: 8th Mar 2011, 23:00 -
A moment of praise for AnyDVD HD & BD Rebuilder!
By funnel71 in forum Blu-ray RippingReplies: 3Last Post: 30th Jul 2009, 07:10 -
A moment to pimp my Streaming Radio Station
By Faustus in forum Off topicReplies: 0Last Post: 20th Jun 2007, 15:51
