I just moved a Pioneer DVR-111D into a USB external bay, and burned a few discs, and now it keeps stalling and timing out during the burn process.
Using Nero 7 and DVD Shrink 3.2, just updated the drive firmware, and am on my way to pick up some better quality DVDR's. The Nero Burn Log is as follows... and ideas? I'm a bit concered about the Queue again later errors...
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 3/14/2007 11:43:16 AM
NT-SPTI used
Nero API version: 7.8.5.0
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Nero\Nero 7\Core\
Application: ahead\Nero - Burning Rom
Internal Version: 7, 8, 5, 0
Recorder: <PIONEER DVD-RW DVR-111D>Version: 1.23 - HA 1 TA 1 - 7.8.5.0
Adapter driver: <USB 2.0> HA 1
Drive buffer : 2000kB
Bus Type : set to ATAPI (3) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : Hitachi HTS541680J9SA00 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY CDRWDVD CRX880A atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
SONY CDRWDVD CRX880A D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046904kB)
Free physical memory: 637MB (652992kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.4.2007
NeroAPI
10:56:17 AM #1 Phase 112 File APIProgress.cpp, Line 285
DVD-Video files reallocation started
10:56:17 AM #2 Phase 114 File APIProgress.cpp, Line 285
DVD-Video files reallocation completed (no file modified)
10:56:17 AM #3 Phase 111 File APIProgress.cpp, Line 285
DVD-Video files sorted
10:56:17 AM #4 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:56:18 AM #5 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
10:56:18 AM #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
10:56:18 AM #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
10:56:18 AM #8 Text 0 File Burncd.cpp, Line 3499
Turn on Disc-At-Once, using DVD media
10:56:18 AM #9 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2156223 (479:09.48, 4211MB)
10:56:18 AM #10 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO
10:56:18 AM #11 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: PIONEER DVD-RW DVR-111D, Media type: DVD+R
Disc Manufacturer ID: CMC MAG, Media Type ID: M01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
10:56:18 AM #12 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
10:56:18 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2156224 (2156224) = #2156224/479:9.49
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2156224 blocks [E: PIONEER DVD-RW DVR-111D]
10:56:18 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: PIONEER DVD-RW DVR-111D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4415946752, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2156224 | 0 | 0x00
2156224 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:56:18 AM #15 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:56:18 AM #16 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
10:56:18 AM #17 Phase 24 File APIProgress.cpp, Line 285
Caching of files started
10:56:18 AM #18 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
10:56:18 AM #19 Phase 25 File APIProgress.cpp, Line 285
Caching of files completed
10:56:18 AM #20 Phase 36 File APIProgress.cpp, Line 285
Burn process started at 8x (11,080 KB/s)
10:56:18 AM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:56:18 AM #22 Text 0 File Cdrdrv.cpp, Line 9856
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: CMC.MAG.
Media type ID: M01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38 ...CMC.MAG.M01.8
23 54 37 18 00 3E 6E 00 - 70 62 15 15 0B 0B 08 08 #T7..>n.pb......
01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
10:56:18 AM #23 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x049addc0: Len x648
10:56:18 AM #24 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: Yes
10:56:18 AM #25 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
10:56:19 AM #26 Text 0 File Cdrdrv.cpp, Line 1338
10:56:19.921 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:50 AM #27 Text 0 File Cdrdrv.cpp, Line 1338
10:56:50.906 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:50 AM #28 Text 0 File Cdrdrv.cpp, Line 1338
10:56:50.937 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:50 AM #29 Text 0 File Cdrdrv.cpp, Line 1338
10:56:50.968 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:50 AM #30 Text 0 File Cdrdrv.cpp, Line 1338
10:56:50.984 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #31 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.015 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #32 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.046 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #33 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.062 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #34 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.093 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #35 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.109 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #36 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.140 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #37 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.171 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #38 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.187 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #39 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.218 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #40 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.250 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #41 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.265 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #42 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.359 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #43 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.500 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #44 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.531 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #45 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.562 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #46 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.593 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #47 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.609 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #48 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.640 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #49 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.671 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #50 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.687 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #51 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.718 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #52 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.750 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #53 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.765 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:51 AM #54 Text 0 File Cdrdrv.cpp, Line 1338
10:56:51.843 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #55 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.015 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #56 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.046 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #57 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.078 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #58 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.109 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #59 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.125 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #60 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.156 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #61 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.187 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #62 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.203 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #63 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.234 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #64 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.265 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #65 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.281 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #66 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.312 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #67 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.343 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #68 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.359 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #69 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.390 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #70 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.406 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #71 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.437 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #72 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.468 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #73 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.484 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #74 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.515 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #75 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.531 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #76 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.562 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #77 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.593 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #78 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.609 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #79 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.640 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #80 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.671 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #81 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.703 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #82 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.718 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #83 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.750 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #84 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.765 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #85 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.796 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #86 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.828 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #87 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.843 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #88 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.875 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #89 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.906 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #90 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.937 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #91 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.953 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:52 AM #92 Text 0 File Cdrdrv.cpp, Line 1338
10:56:52.984 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #93 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.015 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #94 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.031 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #95 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.062 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #96 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.093 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #97 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.125 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #98 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.140 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #99 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.171 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #100 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.203 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #101 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.218 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #102 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.250 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #103 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.281 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #104 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.296 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #105 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.328 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #106 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.359 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #107 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.375 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #108 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.406 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #109 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.437 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #110 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.453 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #111 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.484 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #112 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.500 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #113 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.531 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #114 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.562 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #115 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.578 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #116 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.609 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #117 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.640 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #118 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.656 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #119 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.687 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #120 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.718 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #121 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.734 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #122 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.765 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #123 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.796 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #124 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.812 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:56:53 AM #125 Text 0 File Cdrdrv.cpp, Line 1338
10:56:53.843 - E: PIONEER DVD-RW DVR-111D : Queue again later
11:05:33 AM #126 SPTI -600 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 0D A4 E0 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x0b6d1480: Len x10000
0x00 00 01 BA 44 16 47 8D B6 03 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 6E DF FC DD 7B B3 BD 37 5E
0x5B 31 E7 0E E3 CC FF 07 9F 58 6E EF 94 DD 27 B2
11:05:33 AM #127 CDR -600 File Writer.cpp, Line 303
Device not available
11:05:43 AM #128 SPTI -600 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
11:05:43 AM #129 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5B 01 06 00 00 00 00 00 00 00 00 00
11:05:43 AM #130 Text 0 File DVDPlusRW.cpp, Line 934
EndDAO: Last written address 894176
11:05:43 AM #131 CDR -600 File WriterStatus.cpp, Line 162
11:05:43 AM #132 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
11:05:43 AM #133 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5A 00 05 00 00 00 00 00 48 00
Buffer x049c2740: Len x48
11:05:52 AM #134 Phase 38 File APIProgress.cpp, Line 285
Burn process failed at 8x (11,080 KB/s)
11:05:56 AM #135 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
11:05:56 AM #136 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
11:05:56 AM #137 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x1E 00 00 00 00 00 00 00 00 00 00 00
11:06:16 AM #138 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
11:06:16 AM #139 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
11:06:16 AM #140 Text 0 File SCSIPTICommands.cpp, Line 421
UnLockMCN - completed with error 55 for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 2:07:32 PM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 2/22/2007 10:29:52 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.43J, size=36624 bytes, created 2/22/2007 10:29:52 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 13 of 13
Most External Enclosure's the drive needs to be set to Master. Check That First..
Yeah, the drive is set to master.
Also, when the Burner freezes up, the open tray button stops working until the drive is powered down, and sometimes it even seems to disappear from My Computer. -
gh0st,
All those atapi error codes of 000000 near the end are from the burning software losing contact with the drive, kind of like when you lose someone on a cell phone. Nero sends a sequence of commands to the drive, basically saying "Hello, are you still there?", but when the drive doesn't answer, all Nero can do is terminate the burn (hangs up the phone). Almost certainly, the drive was also trying to send information to Nero, but when it never hears back from Nero, it just sits there and waits.
It sounds like you've used that drive successfully (internally), so the problem isn't likely to be the drive. Nero dutifully did everything it reasonably could to re-establish contact, so it's not the software. Most likely, you have a bad connection somewhere, a faulty cable, or the external box you put the drive in isn't working correctly.
Since these were your first posts here, welcome to VideoHelp. -
Thanks VegasBud
I should mention that after the drive locks up in mid burn, being completely unresponsive to the open tray button, I believe on this attempt that the burn log is from, I got tired of waiting for it to time out as it had been doing, and flipped the power switch on the drive to hurry things along.
I'll try a different USB cable, and have also updated to the latest firmware, and gotten some better blanks, Verbatim DVD+R's, and I plan on trying to burn again at a much lower speed. If it fails again, I'll let it time out and post a burn log with out my impatient meddling.
If that doesn't work, I'll return the drive bay and try another.
Oh yeah, it did burn three good discs out of ten attempts on the USB bay, so it worked a little of the time anyway. -
gh0st,
I noticed your computer is kinda old. The USB port on the PC may be version 1.1 or even 1.0. USB 1.1 may not be fast enough to transfer data to your burner. -
Well, it's a three month old Dell Laptop, so it isn't all THAT old.
I know computers go obsolete fast, but come on!
I'm not positive, but I'm pretty sure it's USB 2.0.
Anyway, did all the previously listed stuff, and tried burning to a RW disc, wasting DVD-R's is getting a little old. Burned a x1 speed and the same thing happened. Burn log as follows:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Recorder: <PIONEER DVD-RW DVR-111D>Version: 1.29 - HA 1 TA 3 - 7.8.5.0
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 634MB (649308kB)
Use Inquiry : 1
21.4.2007
NeroAPI
9:46:16 PM #1 Phase 112 File APIProgress.cpp, Line 285
9:46:16 PM #2 Phase 114 File APIProgress.cpp, Line 285
9:46:17 PM #3 Phase 111 File APIProgress.cpp, Line 285
9:46:17 PM #4 Text 0 File SCSIPTICommands.cpp, Line 411
9:46:17 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 838
9:46:17 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
9:46:17 PM #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
9:46:17 PM #8 Text 0 File Burncd.cpp, Line 3499
9:46:17 PM #9 Text 0 File SCSIPTICommands.cpp, Line 209
9:46:17 PM #10 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Code: 0x24
Sense Qual: 0x00
Buffer x049fd940: Len x648
9:47:13 PM #11 Text 0 File SCSIPTICommands.cpp, Line 254
9:47:13 PM #12 Text 0 File Cdrdrv.cpp, Line 11214
9:47:48 PM #13 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
9:47:48 PM #14 Text 0 File DlgWaitCD.cpp, Line 319
9:47:48 PM #15 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: PIONEER DVD-RW DVR-111D, Media type: DVD-RW
Disc Manufacturer: RITEKW - 01
Disc Application Code: 64, Disc Physical Code: 214
9:47:48 PM #16 Text 0 File DlgWaitCD.cpp, Line 493
Disc not empty. Insert empty disc.
(Medium in drive: DVD-RW. Medium required by compilation: DVD R/RW, DVD R DL.)
Accessing disc...
9:47:48 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 793
9:47:48 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 995
DAO infos:
MCN: ""
DAO layout:
9:47:48 PM #19 Text 0 File SCSIPTICommands.cpp, Line 209
9:47:48 PM #20 Text 0 File Burncd.cpp, Line 4278
9:47:48 PM #21 Phase 24 File APIProgress.cpp, Line 285
9:47:48 PM #22 Text 0 File Burncd.cpp, Line 4397
9:47:48 PM #23 Phase 25 File APIProgress.cpp, Line 285
9:47:48 PM #24 Phase 36 File APIProgress.cpp, Line 285
Burn process started at 1x (1,385 KB/s)
9:47:48 PM #25 Text 0 File ThreadedTransferInterface.cpp, Line 2721
9:47:48 PM #26 Text 0 File DVDR.cpp, Line 3192
Recording mode: Sequential Recording Mode
9:47:48 PM #27 Text 0 File DVDR.cpp, Line 3348
9:47:48 PM #28 SPTI -1066 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x24
Sense Qual: 0x00
Buffer x04a212c0: Len x648
9:47:48 PM #29 Text 0 File Cdrdrv.cpp, Line 9856
Book Type: DVD-RW (3), Part Version: 1.1x (2)
Revision number of maximum recording speed: -
Revision number of minimum recording speed: -
Revision number table of recording speed: - - - - - - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
9:47:48 PM #30 Text 0 File ThreadedTransfer.cpp, Line 269
9:47:50 PM #31 Text 0 File Cdrdrv.cpp, Line 1338
21:47:50.531 - E: PIONEER DVD-RW DVR-111D : Queue again later
9:49:20 PM #32 Text 0 File Cdrdrv.cpp, Line 1338
21:49:20.453 - E: PIONEER DVD-RW DVR-111D : Queue again later
10:17:28 PM #33 SPTI -600 File SCSIPassThrough.cpp, Line 179
CdRom3: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 0B 45 E0 00 00 20 00 00 00
Buffer x076e1500: Len x10000
0x00 00 01 BA 44 2E 1F D6 DD 01 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 60 DC 01 90 0E 8B 48 06 80
0x3B 01 D8 63 8E 03 21 80 3A 59 71 0C 30 0A 20 AD
10:17:28 PM #34 CDR -600 File Writer.cpp, Line 303
10:17:33 PM #35 SPTI -600 File SCSIPassThrough.cpp, Line 179
CdRom3: SCSIStatus(x00) WinError(55) NeroError(-600)
Sense Code: 0x00
Sense Qual: 0x00
Buffer x05112b80: Len x48
10:17:34 PM #36 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
10:17:34 PM #37 Text 0 File DVDR.cpp, Line 3750
EndDAO: Last written address was 738783 (B45DFh)
10:17:34 PM #38 CDR -600 File WriterStatus.cpp, Line 162
10:17:34 PM #39 TRANSFER -24 File WriterStatus.cpp, Line 162
10:17:34 PM #40 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
10:17:35 PM #41 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
10:17:35 PM #42 Phase 38 File APIProgress.cpp, Line 285
Burn process failed at 1x (1,385 KB/s)
10:17:36 PM #43 Text 0 File AudioCompilationImpl.cpp, Line 863
10:17:36 PM #44 Text 0 File AudioCompilationImpl.cpp, Line 892
10:17:36 PM #45 SPTI -600 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x00
Sense Qual: 0x00
10:17:56 PM #46 Text 0 File SCSIPTICommands.cpp, Line 254
10:17:56 PM #47 Text 0 File Cdrdrv.cpp, Line 11214
10:17:56 PM #48 Text 0 File SCSIPTICommands.cpp, Line 421
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
gh0st,
Just for completeness, the log does show that USB 2.0 is being used.
The same exact problem is still occurring. If you tried a different USB cable, and checked the drive connections in the external box, that pretty much leaves the external box itself as the source of the problem, unless you have had problems with other USB devices on that computer (not very likely...just being thorough).
By the way, I probably should have mentioned before that with that particular error, the media isn't the problem. It's purely a problem of the drive and the computer losing the ability to communicate sometime during the burning process. -
External enclosure chipset is likely.
I'm thinking you are right Lordsmurf.
After doing more searching on the net, I've found NUMEROUS people with similar problems when running WinXP, an External USB drive Bay with USB 2.0.
No one has quite pegged it down yet, although ALI chipsets on the enclosure seem to be at least partially responsible.
Apparently, running through a USB 1.o hub may help, but will slow things down. I'll give that a try and update here. -
Has firmware been updated? I know there are different TDB firmwares for external and internal drives from the TDB link from CDFreaks, and I'd guess there'd be different official firmwares depending on how drive is connected although I've not used any official firmwares since testing the original before cross flashing mine to 111L.
Yeah, one of the first things I tried was updating the firmware. Still no go, and I can't seem to find my old USB hub to try the USB 1.0 thing.
Looks like I'll be taking the enclosure back and exchanging it for a Firewire version, which seems to solve the majority of these problems.
Geez, I remember back in the good ol' days of computing when stuff actually worked... It seems like every single thing I've done with computers lately results in some kind of incompatability issue that nobody understands.
I mean seriously, Windows Vista doesn't even support the middle mouse button for Logitech??!? And this is an upgrade???
OK, rant mode off... -
Well exchanged the Drive bay for a Firewire/USB 2.0 combo enclosure, and didn't even need to switch to firewire. Burns like a dream through the USB now.
Thanks all for your advice and information.
Imgburn keeps making me more expensive coasters
By jbitakis in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 12:32 -
New BD Burner--Just Coasters--Suggestions?
By wwaag in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Dec 2010, 18:24 -
Making alot of Bluray coasters
By bpstyxman in forum Authoring (Blu-ray)Replies: 6Last Post: 13th May 2009, 02:09 -
Making some expensive DL coasters (Help!)
By nchd in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2009, 12:50 -
Roxio 8 misunderestimates DVD capacity? making lotsa coasters...
By ahhaa in forum ComputerReplies: 8Last Post: 7th Sep 2008, 18:57
