Is there some general rule to go by when selecting the resolution when converting a DVD movie to AVI? I have an archos AV500 portable video player that I carry when I travel. It is much easier than carrying a portable DVD player and all the videos are on the hard drive of the Archos. It plays DivX AVI's, so I have to convert anything I want to put in it. Whenever I rip a DVD to AVI, after 3 hours of processing, the final product is either stretched or squashed or really tiny on the PC screen in WM10.
Is there a standard resolution size for DVD movies that are widescreen and full screen and a standard resolution size equivalent that I can always set to when converting them to AVI?
or some formula to use? A lot of software indicates taht the resolution has to be multiple of 16, but I can't seem to figure it out.
Thanks for any help!
Jerold
what is the resolution of your screen, 320*240 QVGA
if so then you can't get full screen at 16:9
you can get padded screen full width but not full height to maintain aspect ratio, OR you can crop the sides of the video off and get full screen in the correct 4:3 ratio(of the display) but with the sides of the video chopped off, Super can give you these conversions
for the first one set for 320*240 open the PAD option and add 24 pixels top and 24 pixels bottom
this should give you a screen with a video section that is 320*192 and a 24 pixel black bar on top and bottom,
the video way not be a perfect 16:9 but it will be close
16:9 is likely closer to 320*180 with 30 pixel borders
or you can crop from 720*480 to 640*480 then reduce to 320*240, NO padding full screen no distortion ,BUT you will be missing the left and right edges of the movie
installing an OS on a thumb drive
By deadrats in forum ComputerReplies: 9Last Post: 25th Apr 2011, 13:09 -
DVP5990 and thumb drives
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 16Last Post: 9th Nov 2009, 21:34 -
4g USB Thumb Drive - Unknown Device ???
By blinky88 in forum ComputerReplies: 14Last Post: 24th Aug 2009, 03:35 -
thumb images yet?
By catdaddio6 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Apr 2009, 03:02 -
Fairuse Wizard settings - looking for rules of thumb
By JamesNG in forum DVD RippingReplies: 3Last Post: 29th Jul 2008, 21:01
