I have a project in Sony Vegas that has 1080i, 720i, high res stills and some CG that I can output at whatever I want. I would like to get the best out of my 1080i, even at the expense of the others. It will be played on many monitors, but I would like to default to my 1080i LCOS tv. I don't care how long a render will take or how many discs it needs to fit on as long as I get the best quality possible. Please answer the following questions according to the above info:
General questions:
- I assume I render as regular 720, but I have read on some posts that I could get better quality if I do 24 fps, should I?
- Either way, 29.97 or 24, should I do interlaced since that's what the source is and it will be played out on a 1080i monitor?
Vegas specific questions:
- Do I check the box that says "stretch to fill frame (do not letterbox)" or not since it will play on my 16:9 tv?
- Do I set project properties to Lower field first and none on the deinterlace method?
- What should I do for the various clip types when it comes to 1) resample and 2) reduce interlace flicker?
Thanks!
Carson
Results 1 to 1 of 1
Multiple Mpeg sources per frame without reencoding
By bisonrav in forum Video ConversionReplies: 1Last Post: 17th Sep 2011, 05:28 -
Very specific question regarding capturing multiple sources
By Acester47 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 21:04 -
Recording multiple audio sources in realtime
By Cyber Akuma in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2010, 21:44 -
DVD authoring from multiple sources?
By architectofpain in forum Authoring (DVD)Replies: 9Last Post: 24th Oct 2008, 23:34 -
Capturing multiple video sources
By mgy999a in forum Capturing and VCRReplies: 8Last Post: 14th Apr 2008, 03:20
