    Apr 2007
    Hey,
    Ive been trying to rip a perfectly new movie on mac the ripper and it keeps telling me that it "cant read dvd file structure". does anyone know what this means or how I can get around it?
    Nov 2006
    try the mac the ripper forums at http://www.ripdifferent.com/phpbb2/index.php. New DVDs are incorporating blank or "zero cells" that MTR can't handle yet unless you donate ($35?) for the new beta version and use in in conjunction with DVD2ONEX (DETOX) ($45?). However, some have found a way to use the current version with detox, if you have detox already. I'm waiting for the next public release of MTR, myself. Or, if you're really ambitious, you could use the current release of MTR/ detox method, but instead of detox, use the free myDVDedit to remove the zero cells. I haven't done it myself, but I have a theory that it is possible. Best of luck!
    Jan 2006
    1) Disable File Size Calculation in Preferences
    2) Use MTR 2.6.6 in Title Set Extraction
    Make sure you choose the Title that is Main
    Feature. Ignore Warning. Let it RIP!
    3) Use DVD2oneX to check for zero cells
    4) Burn with DVD2oneX or another App.
    If this doesn't work, go to RipDifferent, Register,Donate and get the latest beta which is MTR3.0r14d to use on the newer DVD from companies like Sony.
  4. Originally Posted by lawnman
    how do u check for zero cells in dvd2onex? i've been looking around for it but cant figure it out
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    You have to do a Movie Only shrink in DTOX,
    NOT a Full Disc Compression.
    Choose Movie Only, DTOX will select the main
    movie track, and just follow down the tree on
    the left Window until you get to past language and captions
    to Chapter/Cells, and check for Cells that may be 1:00, 2:00
    mins or even 0:00 minutes, but say 0.0MB.
    These are zero cells.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  6. Originally Posted by terryj
    thanks for the quick response
  7. Member terryj's Avatar
    U R Welcome!
    Urban Mac User
