I'm going AVI-->MPEG2-->DVD files. I use TMPGEnc Xpress 4.0 for the 1st step, and GUI for DVD Author to convert to DVD files. When I try to author I'm getting a prompt, just after I drag the MPEG2 file into the blue area, that says "...inconsistent timecodes..". I click continue, and then somewhere along the way I get another prompt about not having "navigation packs".
It looks like it would have allowed me to continue despite the potential problems, but I was wary of all these warnings, so instead I tried to demultiplex using TMPGEnc Xpress, and then authoring using the individual video and audio streams, but it's not working right for some reason.
When I play back the resulting DVD files on my PC the movie stutters. The first time I tried authoring the demultiplexed streams, I actually went ahead and burned the resulting files to a DVD, but I didn't get any audio when I played it in my player. I think this was because I selected an incompatible audio format, but whatever, FYI I guess, in case it could be related. Every attempt after this resulted in the playback stuttering, and I didn't want to waste another DVD before I hit you guys up.
And I have required codecs.
I searched around for threads covering the above prompts, but it didn't do much good. I got some results but they never covered my specific problem.
Thanx
You can set up TMPGEnc to directly create elementary streams (at least TMPGEnc 2.5.xx has this option), then you do not need to demux.
...playback stuttering
Sounds like a frame rate problem.
Check the properties for the video and audio files carefully...
Audio must be 48 kHz mp2 or ac3 (or wav if muxman is used)
The frame rate (25 for PAL or 29.97 for NTSC) should fit the the default project settings (PAL or NTSC), other values are not allowed.
Aspect ratio must be either 4:3 or 16:9, other values are not allowed.
When you encode AVI to mpeg with TMPGEnc, you often run into problems if the audio in the AVI is a VBR MP3 stream (at least this caused a lot of problems with TMPGEnc 2.5.xx).
You may post a screenie from gspot or similar with the properties of your AVI file and the encoded streams (before authoring), then we can have a look...GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
It looks like the file is actually 23.97 FPS, so I guess I can try the 2:3 pulldown. Everything else checked out.
-I encoded to NTSC
-the audio in the AVI file is AC3.
-The demuxing was an after thought which is why I ran it through TMPGEnc a 2nd time. I didn't anticipate needing seperate streams, but maybe I should always demux initially.
So what about inconsistent timecodes, or no navigation packs?
Thanks. I guess I'll have to continue on the deduction method. Meanwhile I'm building an extensive coaster collection. -
I always test play on the PC first, and if I have any doubts, burn to an RW to test on standalones. That should reduce the coaster count.
As for your other problems . . . . I don't use tmpgenc Xpress, however I never encode to programme streams when I am going to author, and if I am using a programme stream taken from a FTA digital broadcast then I always demux. Authoring always gooes smoother when you start with elementary streams.Read my blog here.
...So what about inconsistent timecodes, or no navigation packs?
The internal multiplexer in tmpgenc does not a good job if you want to author the video on a DVD (see also guns1ingers comment...).
If you have encoded the file with 23.97 FPS, use dgpulldown to insert the 2:3 pulldown flags. It's the best application for this job.GUI for dvdauthor:
Alright I'll keep trying different things. Maybe I'll demux with VirtualDubMOD, use TMPGEnc to transcode and multiplex, then author.
I also just looked at a guide that included TMPGEnc transcoding, and I think there may have been some settings selected differently than when I did it. I'll report back. Thanks again. -
This is lame. Nothing works. I guess I could try another file, maybe ten, as a control just to see what's up.
Anination in GFD
By akakiami in forum Authoring (DVD)Replies: 3Last Post: 21st Jan 2011, 04:55 -
GFD - Menu colors problem
By jsbullock in forum Authoring (DVD)Replies: 1Last Post: 19th May 2009, 11:25 -
GfD: delete a submenu?
By AlanHK in forum Authoring (DVD)Replies: 11Last Post: 22nd Mar 2009, 07:08 -
SUP format in SubtitleCreator (to use in GfD)
By michcio in forum SubtitleReplies: 70Last Post: 15th Aug 2008, 08:43 -
GFD - transitions between menus
By dani96 in forum Authoring (DVD)Replies: 0Last Post: 24th Jul 2008, 06:23
