Results 1 to 12 of 12
    Apr 2007
    Bahrain
    Hi ..
    I wanted to do something important , and I knew that you would help me
    I'm trying to make a data dvd - pictures and videos - that the videos within works on the dvd player ..
    I want to do this for two reasons ,,
    1- because I want to add a pictures to the dvd ..
    2- I want to add more than 25 videos .. that all togother long is more than 5 hours , but their size is only 3 Gb . So it wouldn't fit to a video dvd - wich can take only 2 hours - .
    3- because I want to make it fastly , without any complicated thing .
    So ,, you see , I have to make a data dvd , that videos works on dvd player .
    Of course I dont want a menu or subtitle or anything .
    You see , when I make a basic data dvd , its' videos doesn't work on the dvd player , but its' pictures and sounds do . So I need some kind of videos ( .*** ) that works on dvd , Or if you have a better way .
    I hope you help me
    Thanks alot , and goodbye .
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    What a DVD player can do, besides playing a Video DVD, is entirely dependent on the individual player model. So... you see, you have to find out what kind (if any) of video your player can handle, besides std Video DVD content, and then encode your video to that specification.
    /Mats
    Apr 2007
    Bahrain
    Hi ..
    I got on of the best LG dvds ..
    and I'm gona try now ..
    thanks ..
    and Goodbye ..
    Apr 2007
    Bahrain
    Hi ..
    I couldn't find anything useful written on the menu of the dvd ..
    So , is there any type of videos that can be played on all dvds ?
    on the menu ,, its written that the dvd can open all types of pictures , and most of audio , but - as I said - there was nothing about videos .
    thanks alot .. goodbye ..
    Apr 2007
    Bahrain
    Hi again ..
    No matter , if there is any way that makes me able to make a video dvd , that can handle more than 5 hours - I mean it depends to the size not the duration - , then great .
    thanks alot ..
    and Goodbye ..
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    The only type of video that can be played on all DVD players, is video conforming to the Video DVD specifications - see top left, WHAT IS - DVD.
    Video bitrate determines how much (in time) a DVD can hold. At VCD quality and bitrate (which is DVD compliant), you can fit 6-7 hours worth of video onto a DVD-5
    /Mats
  7. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    All DVD players conform to https://www.videohelp.com/dvd
    This will always include authoring a multiplexed VOB + IFO and BUP files in a Video_TS folder.
    Individual players may do other things as specified in their manual. This may include direct display of JPG stills, or playing certain audio or video files from a root directory on a data DVD.
    http://www.kiva.org/about
    Apr 2007
    Bahrain
    thanks alot ,,
    about what you said , mats.hogberg , its ok .. the quality of VCD in a dvd-5 , thats exaclty what I wanted ,,
    is there a tut for this , or a prgram at least .
    thanks alot , and goodbye ..
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Most mpg encoders (like TMPGEnc) have a VCD preset. Use this when you encode your videos for your DVD. If possible, change audio sampling frequency to 48 kHz, as this is what DVD audio should be, even if some DVD authoring apps (like TDA) will upsample VCD 44.1 kHz audio to 48 kHz for you.
    /Mats
    Apr 2007
    Bahrain
    ok .. I'll try now ,
    so all I have to do is to chose the VCD quality , and the audio sampling frequency , then I'll be able to make a dvd with video mire than 5 hours
    thanks alot .
    and Goodbye ..
  11. Member edDV's Avatar
    Mar 2004
    thanks alot .
    and Goodbye ..
    You will still have to author it into a VIDEO_TS folder (VOB, IFO, BUP) to play as a DVD and have DVD Menus.
  12. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, of course authoring is required - I suggest TMPGEnc DVD Author to that end - has a 30 day trial.
    /Mats
