I have a home video that is tilted a few degrees because the camera was on a tilted tripod when it was shot. Is there a good editor / technique that can be used to straighten it?
Results 1 to 13 of 13
Hi-
If you're handy with AviSynth, the EffectsRotation function, part of the EffectsMany plugin, can untilt it:
http://avisynth.org/vcmohan/EffectsMany/EffectsMany_index.html -
Manono, thank you for your answer. Avisynth is a product that I want to spend some time learning later this year when I have the time to dedicate to it. But meanwhile, I'm looking for a GUI editor that has this type of filter in it or available as an add-in.
I see that you are one of the most knowledgeable and helpful members of this forum. I, and I'm sure a lot of others, thank you for you very helpful contribution. -
When you don't want to tackle Avisynth, there is always VD to fall back on. I use VirtualDub Mod most of the time. Rotate2, which I believe is a included filter in VD, should do the trick.
If you dig around a little in http://neuron2.net/ , you will likely find a few more filters that will do what you want. A easier to read listing of many VD filters is here: http://www.thedeemon.com/VirtualDubFilters/
If your source video is DV, you may need a DV codec to do this with VD or VDM. I use the Panasonic DV Codec, then you can output as DV, or use my preferred method, frameserve directly to TMPGEnc encoder.
But if you need to do this more often and you want more control and quality (And speed), Avisynth may be well worth learning. It's not so hard if you use a GUI with it. -
You ought to take the 30 minutes or so to get to learn basic AVISynth. Using it in conjunction with VirtualDub(mod(mpeg2)) you can create results that are superior to software packages (like Premiere).
There is a plugin called (I think) AvP - for Aliens vs Predators (also, I think) that gives you GUI-like features.
Here's a basic script that will get you started:
Code:directshowsource("YOUR_VIDEO_PATH\YOUR_VIDEO.AVI") bilinearresize(720,480) ConvertToYUY2()
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
If the video is interlaced (and camcorder footage likely is) you will need an interlace aware rotation filter (VirtualDub's Rotate2 is not) or you will need to deinterlace before rotating.
Originally Posted by redwudz
Thanks, jagabo. I haven't had the need to rotate a DV file, but your info will be stored away when that does come up. The same problem would be possible with a MPEG file that needs to be converted to Divx or similar. It all helps.
I'm definitely not up to speed with AVIsynth, but that's one of my future projects. Thanks again. -
redwudz, Here's a thread with some discussion of the technique:
https://forum.videohelp.com/viewtopic.php?p=1681096#1681096
Oh, I see manono gave a link to a filter that can do the rotation. -
Is there any commercially available product that can do this? I have a similar problem with a video file that I have. The camcorder was tilted pretty badly, Can Sony Vegas or TMPGEnc do this? Because I'm not familiar with VirtualDub or AVISyth. Thanks.
I was able to easily remove the tilt in the video I asked about when I opened this thread by using Magix Edit PRO 11. All you have to do after you have loaded your movie is right click on the time line and select "Image Size and Position". It opens a dialog box with a preview window in it. There is a knob you can rotate using your mouse. This rotates the frame by any amount you choose - it's very easy to do. Since there is a preview window you can adjust it exactly as you need it to be. You will have to crop your video after you do this to trim off the edges that are rotated our of the frame.
How to remove grain in video
By skorpinok in forum Video ConversionReplies: 19Last Post: 13th Dec 2010, 21:06 -
How I can remove a medicine ad from my video cd
By nusratjaveid in forum EditingReplies: 1Last Post: 2nd Jun 2010, 10:18 -
How to 'tilt and scan' video?
By limesherbert in forum EditingReplies: 1Last Post: 18th Apr 2010, 22:24 -
Intel Quad - full tilt boogie
By awsedr in forum ffmpegX general discussionReplies: 5Last Post: 29th Jun 2008, 11:33 -
Help remove watermark from video
By Syro_Str0m in forum RestorationReplies: 1Last Post: 14th Dec 2007, 08:46
