  1. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    G'day all
    How can I make Opera my default Internet browser? When I click on a link it defaults to (stupid slow) IE and cannot change it. I have to copy the address from the address bar and paste it in Opera or FF.
    Thanks and Regards from Down Under.
    John
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    See if this works for ya.
    Opera 7.x:
    * Select "File | Preferences" from the main menu in Opera.
    * Change to the "Default Application" tab.
    * Check the "Check if Opera is default browser on startup" option.
    * Click "OK".
    * Close all Opera windows (for best results, restart the system). Finally, restart Opera.
    * When the "Would you like to use Opera as your default application for viewing web pages?" prompt appears, click "Yes" to make Opera the default browser.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Some applications will only open pages in IE, but the above should work for general use.
    Read my blog here.
  4. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Thanks guys. I'll let you know.
    John
  5. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Thanks Faustus
    It worked with FF. Could not do it with Opera but that's OK, as long as it won't default to IE.
    Thank you
    John
