At my inlaws they have a version of nero that takes any avi's (say I select 7 40min avis) and then compresses them to fit on a 4.7gb disc (quality is not an issue, just comfrtable to watch which nero does).
My nero is the version before and does not have this feature.
I can do them individually with super but then have to guess bitrates and reencode (my super conversions always need reencoding in vegas before dvd architect accepts them as dvd compliant) but dont want any hassle or mucking around - fire and forget if you know what I mean (remember ultimate quality is not an issue).
Does this exist?
DivXtoDVD, older freeware version.
http://www.free-codecs.com/DivXToDVD_download.htm -
7 x 40 minutes must look very average after Nero has done it's thing.
You could also look at AVI2DVD, TheFilmMachine, DVD Flick. All are free.
As for bitrates - there is no guess work involved - you know the running time so use a bitrate calculator. SUPER can also encode at VCD resolution, which is what you should be using at these running times.Read my blog here.
FAVC can also do this. If you select Half-D1 resolution I'd think the output would be acceptable.
The FilmMachine is pretty good at that, though all the clips have to be the same resolution. And it does not do separate VTS'es for each clip.
Freeware to compress dvd9 to dvd5?
By Topher5000 in forum DVD RippingReplies: 11Last Post: 27th Aug 2016, 09:49 -
Your Recommendation for Best Freeware DVD Ripper and Converter
By charmedlife417 in forum Video ConversionReplies: 22Last Post: 28th Oct 2011, 13:36 -
Compress 50GB avi to one DVD
By pauldaymond in forum Video ConversionReplies: 5Last Post: 27th Mar 2009, 11:53 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 18:52 -
Best AVI -> MPEG2 converter? (Freeware??)
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 23:58
