  1. is it better then the Divx/XviD codec?
    Thanks!!!
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Should be more efficient, yes (same quality/lower bitrate or better quality/same bitrate) but reportedly takes "forever" to encode with, and playback support is much less. It all boils down to what you mean by "better".
    /Mats
    Dec 2004
    Triptonia
    reportedly takes "forever" to encode with...
    Perhas thinking of h.264...
    h.263
    'A video compression scheme defined by the ITU, originally for use in video telephony and related systems; particularly suited to operation at very low rates'
    Mpeg4 is considered an evolution on h.263.
    FLV contains an H263 variant in sorenson spark (SVQ), although it's reported that the latest SVQ3 is a tweaked h.264.
    (FLV can also contain on VP6 since flash 8.)
    A link with some info on h263
    http://www.h263l.com
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Ah - yes! I should read more closely.
    /Mats
  5. thanks for your reply...
    so according to what you're saying its better...
    what about compatibility with my DVD Player?
    (Pioneer DV-383)
    is it recgonized as Divx\XviD?
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Highly unlikely.
    /Mats
  7. mats.hogberg, OK Thanks man!
