This seems to be a common problem from previous topics but I'm starting a new topic about it anyway seeing as, from what I've observed on this forum, it still has yet to be solved. I need to convert an mov file to flv. It takes less than a second to "encode" and results in a 0kb file that doesn't do anything. Setting the scale from fast bilinear to bilinear is not an option for when encoding to flash. I've checked "invert mapping" for the audio. I've made sure that the size is set to 320x240. The name of my hard drive does not have any spaces or unusual characters. These have all been suggestions on previous threads but none of this helps. Has anyone found a solution to this problem?
Here's my log if it helps:
Encoding started on Wed Apr 18 23:35:37 CDT 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/username/Desktop/robotobackup/website/sunny local/sunnlandcomp 2.mov':
Duration: 00:08:59.7, start: 0.000000, bitrate: 9728 kb/s
Stream #0.0(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 720x480
Number of stream maps must match number of output streams
FLV conversion...
By mjl1297 in forum Video ConversionReplies: 11Last Post: 11th Apr 2011, 10:48 -
Problem with MOV > FLV conversion
By sprinke in forum ffmpegX general discussionReplies: 1Last Post: 12th Feb 2011, 21:11 -
FLV conversion problem
By CSULB71 in forum Video ConversionReplies: 16Last Post: 22nd Dec 2010, 19:44 -
FLV Conversion Problem [possibly corrupted during download]
By SCkid in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 17:56 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09
