I just downloaded the April 2007 version and am using a 30-day demo key. I added a MPG file to the project list, then dragged it into the input window. The video plays and for about 30 seconds the user interface buttons work, but then the buttons all stop working. If the video is playing is continues to play but I can't do anything else but kill it with task manager. I let it go to the end of the video once but things didn't get better. Anyone else seen this?
I contacted the Womble folks but so far they haven't been able to duplicate the problem. I'm running WinXP Pro SP2.
Tonight I used a little tool called MMVIEW to get a list of all the CODECs on my system. I disabled a few of them and tried things again. The first video played fine and the buttons continued to work, so I thought I was on to something. But the second video hung the UI again. I killed the app with Task Manager and disabled a few more CODECs. MPEG Video Wizard worked fine. I re-enabled all the CODECs expecting to have problems again but didn't - for now.
I'd really like to use this app but I'd like to understand this UI problem before I spend the money. Any suggestions are welcome.
Results 1 to 1 of 1
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Fairuse Wizard 2.8 Hangs
By herzeleid in forum DVD RippingReplies: 5Last Post: 14th Sep 2013, 07:53 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
By newshoes in forum Software PlayingReplies: 10Last Post: 20th Mar 2008, 11:22 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52
