Im tryin to finsih the registration process and after I get my license and I hit the register button it processes for a while and then I get an error that says "internal registration error, please see author"
I think I have D/L everything I was supposed to and made sure my firewall is off. What can be causing this problem???
This is regarding svcd2dvd ver 2.1
When you get the:
"Internal error.
there is an error registering the program.
Please inform the author."
error, it is because the SVCD2DVD.exe file is in use. If you do a quick reboot and try again you should be ok.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Registration Code Error
By ghillman100 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Apr 2011, 11:07 -
New PC/Registration
By sopwithpup in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 31st Aug 2010, 07:13 -
Registration
By guidorobben in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jun 2010, 16:17 -
registration
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2010, 07:20 -
registration
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Nov 2009, 05:10
