alright, I wanna get a dvd ripped but I can't seem to unlock the dvd
I've followed the instructions, but I won't pass the point of actually getting the dvd rip to the harddrive
I've heard that i could open it by playing the dvd, then stoping it
but it doesn't help at all.....I'm all out of ideas, everyone just says to play the cd but it won't help, so I've decided to post here
thank you, cheers
Results 1 to 17 of 17
Which movie is that ? i've yet to see a DVD that can't be ripped
Have you tried with Sector Extractor ? it usually wins where all else fails.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
So you have an authentication problem?
Try this:
Load up PowerDVD (or some other software DVD player). Start playing the movie (this means that the DVD must be authenticated). Then "pause" the playback (not stop).
Now try loading SmartRipper or DVD Decrypter.
Regards.Michael Tam
w: Morsels of Evidence -
Yes yes i have the same problem with the movie therminator 2 i tried everything.
Nothing helps. -
Since I have ripped Terminator 2 (one of the first movies I ever did), i'm thinking maybe your ASPI Layer is bad, I suggest you try updating or doing a reinstall of it.
Best Regards,
Sefy Levy,
got all the aspi layers working, so the problem is not there.
and btw, I've just found out that Fast and the Furious (the movie that I'm trying to rip) has some special new protection or something alike
if anyone has any info, please do reply
I wanna rip that movie BAD.
thanx, cheers -
i'm guessing this is T2 ultimate edition. it's one of the hardest dvdz to rip cuz of it's tons of multi-angles.
first of all, can your dvd-rom even play the DVD at all? i ripped both T2 and fast and furious with very old version of smartripper (so old it doesn't require any aspi). i don't think it's some sort of new encryption.
just like wut others said, play the dvd (maybe for a little bit longer) and then close it and open up smartripper. if that doesn't work, try dvddecryptor and claddvd. otherwise, try getting winDVD. -
If all else fails, get Sector Extractor v1.2, I have yet to see that program fail to rip a DVD! (oh and my T2 is also special edition!).
Best Regards,
Sefy Levy,
ah, everything worked
I just had to play the movie for 10 minutes before actually extracting it
thanx for the help, converting the damn thing as we speak
9 hours this is horroable -
9 hours ? how long is that movie ?
and how fast is your system too ?Email me for faster replies!
Best Regards,
Sefy Levy,
that's already pretty fast....
it takes my athlon 650 about 12 hrs to convert a 2 hr movie (with motion search set to high quality (slow)) -
I think your speed is pretty good, although you haven't said how long is your movie, so it's hard to tell.
Best Regards,
Sefy Levy,
Originally Posted by Spinal_Core
hehehehe, that was a good one Chubb!
Don't you think it's a nice catchy name ? no one else has a CLASSIC guide
But i'm glad to hear you found it usefullEmail me for faster replies!
Best Regards,
Sefy Levy,
he sefy
your guide was the first gide i use and the best.
i only use smartripper and dvdx and made 50 vcd's all perfect.
i have a p3 800 and a 2 hours movie takes 6 hours of my time.
So thanks for your perfect guide men
Greetings from the haque holland :D :D :D :D :) :) :) -
I'm glad to hear you guys like the guide so much, Pinoy informed me that loads of people downloaded the ZIP file of it, if you read our combined post in the Newbie section, i'm currently working on v2.0 of the guide.
The main diffrence will be a Tree - Branch, that you choose what you want, and it will guide you through with all the options for what you picked.
You can sample a "preview" on my webpage (www.sefy.dns2go.com) but I gotta warn you, i'm not done with it, lots of links propably won't work, and the text and images aren't fully ready, it's just for previewing.Email me for faster replies!
Best Regards,
Sefy Levy,
How to author a god damn dvd with subtitles?!
By Redhotpengy in forum MacReplies: 7Last Post: 7th Jan 2012, 04:51 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 19:00 -
How can I unlock the dvd region
By roUndy_sh in forum Video ConversionReplies: 8Last Post: 11th Jun 2009, 00:20 -
help to unlock my dvd/vcr
By wawabig in forum Software PlayingReplies: 2Last Post: 11th Feb 2008, 10:37 -
Damn U DVD Studio Pro! Widescreen DVD Playback on 4:3 Monitors
By TRAK in forum Authoring (DVD)Replies: 2Last Post: 25th Sep 2007, 02:20
