I have a xVid AVI file I'd like to edit down and then convert to a file I can upload to youtube.
What can I use to edit xVid? Should I convert xVid to another file type before editing?
I use Adobe Premiere Pro 2 for editing.
Any suggestions?
What kind of editing?
If it's just hard cuts, you can use vdub, or avimux-gui.
If it's more complex than that. Convert to DV at least. And why not lossless if you have the space. -
What can I use to convert it to DV or "lossless" format?
vdub and a dv codec (canopus, cedocida, panasonic)
install codec.
open vdub, open avi, select full processing and select DV compression.
You'll have to rezise to 720x576 or 720x480. You'll have to have a framerate of 25fps or 29.97fps
or use vdub to go to huffyuv.
I think for adobe (which I've never used) you might want to click the configure button when selecting huffyuv and selecting the 'always suggest RGB...' option.
How do I convert H264 to Xvid-Avi with WinFF?
By KneeRow in forum User guidesReplies: 7Last Post: 21st Sep 2010, 19:04 -
Edit then convert VOB to .AVI? Best way?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 15:16 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 10:55 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
XviD.TG.avi convert to iPod.
By kieran_92 in forum Video ConversionReplies: 7Last Post: 3rd Aug 2007, 05:20
