I have a few movies on my HDD that won't fit on a DVD-5 without MAJOR compression, like 40+%. Is there a way to split them from where they are for burning, or will I have to re-rip, and split them at that point?![]()
Thanks!
There is a way
You can use VobBlanker (free), TMPGEnc DVD Author or Mpeg Video Wizard DVD, last two are also authoring software. No ripping they are already on HD.
If you split it you will have to reauthor other half to play when inserted into the player.
If you want to use computer only, than it does not matter.
I would go and spend money on dual layer DVD, much easier.
Even to get Dual layer burner in US, less than $40.
Than use ImgBurn to burn dual layer DVDs, good software (free-donation if you wish)
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
Splitting bluray movie to 2 bd-r discs
By jayt34 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Jul 2010, 19:50 -
Splitting a Movie into two parts
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 23:25 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
A little help can't seem to burn this movie after ripped to HDD
By f-zer0 in forum Authoring (DVD)Replies: 4Last Post: 10th Apr 2008, 22:13
