How do I connect the two up so I can tape a vcd that i made onto a video tape? Right now my dvd player is hooked upto my vcr because my tv doesnt have a/v inputs, so would that work?
thanks
You will need a Macrovision Disabling on your DVD in order to connect it and be able to record using a VCR.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
i think sefy read this a bit to fast. home made VCD's dont have macrovision. that is if you want to tape a DVD that was purchased in a store.
yes the way you have it connected is correct. i assume you must turn the vcr to line in for the DVD player to play on your TV. if this is correct just hit record on your VCR and record away.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
Yeah, you are right, my apologies, I saw DVD being mentioned, and I didn't notice he was trying to copy a VCD, again, my fault, sorry!
Best Regards,
Sefy Levy,
How do you disable MacroVision??
jimb -
Like was mentioned, you don't need to worry about Macrovision if you are copying a VCD, only DVD's (and new VHS tapes) have Macrovision protection
Best Regards,
Sefy Levy,
Need some help with a DVD/VCR player's audio
By HalloweenJack in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2010, 02:24 -
Not sure if I need a dvd + vcr recorder player with built in tuner or not
By zalman001 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Oct 2008, 11:33 -
DVD/VCR Combo Player
By pepegot1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2008, 12:41 -
jmx player and running the dvd thru the vcr
By MikeDixon in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Dec 2007, 18:05 -
VCR/DVD player with S-Video output
By arturo83 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th May 2007, 03:14
