hi,
i'm using the latest verison of ultraiso on windows xp sp2. i'm sorry this question might seem very noobieish.. but i really have no idea how to do it.
i have a dvd iso that is bigger than a single layer dvd-r.
i do not have a dual layer-dvd drive...![]()
what can i do to split the big iso(7gb. i think its from a dual layer disc , is it?) into 2 single layer dvd-r??? i do not want to change/encode the contents...![]()
and
is it possible not to lose quality or lose the menus???![]()
thanks a lot!
regards,
Results 1 to 13 of 13
you don't miss what you don't know
DVD Fab Platinum or DVD Remake are probably your best bets. You may have to mount the ISO or extract the contents for these programs to work, but you should be able to split the disc into two working parts without sacrificing quality or content.
Read my blog here.
Originally Posted by guns1inger
is dvd remake free? is it easy to use? thanks for the advice again!! :Pyou don't miss what you don't know -
Use shrink to backup iso to DVD-9 > vobBlanker to remove stuff(crap not needed),or split disk > DVDRB to DVD-5 >burn..
Though the DVDRB process will re-encode ,it will preserve best quality backup IMO.....
guns is right ,DVDFab, or DVDRemake ,are probably your best bets,and easier to use.......
But my choice, Shrink >DVD-9 > DVDRB to DVD5> IMGBurn...." Who needs Google, my wife knows everything" -
Originally Posted by t0nee1
oh gosh
seems real hard. i think gotta fork out money already. and run my savings out.you don't miss what you don't know -
but i'll see what i can do. reading up on those tools seems boundless. too much jargon in those apps that i don't understand at allyou don't miss what you don't know -
@ yandao,
don't get discouraged, open shrink go to preferences, set target size to DVD-9 8.5G and backup your iso...now use DVDRB free to backup VIDEO_TS file created by shrink to DVD-5 (single layer disk)...then burn.......
http://www.dvdshrink.info/guides.php
https://www.videohelp.com/tools?tool=DVD_Rebuilder
All free,just keep reading how to section and guides..good luck!!!!!!!" Who needs Google, my wife knows everything" -
Originally Posted by t0nee1you don't miss what you don't know
There are plenty of free, simple to use, quality tools to fit a DVD9 onto a DVD5. Your original post however was to do this while keeping the menus and without encoding. To do this you need tools that can split titles and rebuild the structure so that everything continues to work. Very few tools do this, and the two best I have already listed for you.
If you are willing to compromise slightly, and put a little effort in, you can get a close simulation using free tools, with some re-encoding possibly required.
What you basically need to do is copy the disc contents to your HDD twice. Have a read of this guide for VOBBlanker to see if it will get you started : http://download.videohelp.com/jsoto/guides/VobBlanker/splitdvd9/index.phpRead my blog here.
@ yandao, yes it's still video format!
And listen to the very tired and experienced guns, as well as others suggestions. We were all noobies once upon a time.....
keep reading and learning...Good luck!!!!" Who needs Google, my wife knows everything" -
but i think its very difficult and hard to get to the perfect situation which i want... haha :Pyou don't miss what you don't know
Avi2DVD help Iso too big
By martial4rtist in forum Newbie / General discussionsReplies: 12Last Post: 9th Apr 2011, 17:41 -
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 10:24 -
help -- salvaging a 4gb avi file
By pkpara in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 20:50 -
convert DV to 4GB file
By bensonlo in forum Video ConversionReplies: 3Last Post: 5th Mar 2008, 15:15 -
ISO file to big for CD
By vagg in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 13:02
