I created a VTS menu with DVD Lab Pro with main menu and two title menu.
how can i add sound?
i want to add one sound stream that will apply for ALL the VTS.
Thanks in advance!
You can add audio simply by dragging an audio asset to the menu. It will drop automatically into the audio track under the menu. If the menu is a motion menu then the clip will loop at the end of the video, and not loop the video for the duration of the audio.
You cannot have audio that runs across menus. The DVD specification simply does not allow this to happen, so when you move from menu to menu, the audio will restart.Read my blog here.
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 17:11 -
Need some Menu help from a DVD-lab PRO master
By jeanpave in forum Authoring (DVD)Replies: 13Last Post: 4th May 2010, 15:03 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 17:27 -
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 04:52 -
DVD Lab Pro Menu Troubles
By Freestyler223 in forum Authoring (DVD)Replies: 5Last Post: 21st Dec 2007, 23:30
