Im having a problem with my sv2000 wv20v6 vhs/dvd recorder. Half the time it will not let me record from my vhs. These are NOT protected tapes, they are my own blank tapes I bought to record off of tv. It will start recording anywhere from 5 min to a whole hour before it stops and says "this program is not allowed to be recorded" I can sometimes start over a couple of times, and it will record it, other times, not at all. The tapes are not protected, so any idea why dvd recorder is still telling me it cannot be recorded?
Sounds like your Player/recorder is sensitive to Copy 1, Copy 2, Copy 3.
Your recorder is falsely detecting Macrovision. Probably because of marginal recordings and/or playback. This is a very common problem. Using a VCR with a built in line time base correcter, and/or an external full frame time base correcter should eliminate the problem. Note, both of those start around US$300.
Jagabo is right on the money. I have encountered the same problems with certain home recorded tapes. Poor signal, glitches, and temporary loss of control track can fool the DVD recorder into thinking that its seeing a copyguarded source.
VHS to DVD Recording - 4:3 VHS Becomes Widescreen on DVD
By Ocracoke Pelican in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2011, 14:04 -
Vhs to dvd recording
By JAYHAWK1970 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 20:21 -
VHS To DVD Recording errors
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2010, 13:31 -
Problem recording onto VHS from AV2 - but DVD works normally - help please!
By Sassie in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Jan 2010, 08:15 -
VHS to DVD recording problem - strange line only shows up when viewed on PC
By CodySave in forum DVD & Blu-ray RecordersReplies: 11Last Post: 16th Jul 2007, 03:09
