when i convert a file using auto gk that has more than one angle it doesnt convert correctly. it switches between the two angles throughout the video file. is there a way to fix this? i rip my personal dvd's with dvd fab decrypter if this helps.
Yes, decrypt it properly in the first place. Decrypt using DVDDecrypter set for IFO Mode and choose the angle you want.
With it on the hard drive now, demux using PGCDemux, choose the angle, and set for "Create A PGC Vob". Feed that into AutoGK. -
thank you so much! i've been trying to figure this out for months now ~_~
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
problems with converting TP to AVI using Auto GK
By KaNGaRooBaby in forum Video ConversionReplies: 0Last Post: 16th Aug 2011, 22:50 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Auto Gordian Knot is converting to divx in 4 hours!
By szalaikornel in forum Video ConversionReplies: 8Last Post: 17th Jan 2009, 07:39 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44
