Noticed that FFDShow white sub color is very lame compared i.e. BSPlayer's white sub.
Take a look this picture, upper is FFDShow subtitle and lower BSPlayer. BSPlayer subtitle is much brighter: http://xs.to/xs.php?h=xs114&d=07163&f=subs.jpg
Why FFDShow white is SO lame? It's actually more grey than white.
I would like to use VSFilter and just installed it (again), but i got high CPU usage problems with it. :/
Use Draw subtitles to Overlay surface option in BSplayer and... then compare.
Use Original resolution in DirectVobSub (VSFliter) and... then compare.
Default, VSFilter use different resolution for subtitles.
Use Resize in ffdshow... then compare. -
You can try ffdshow tryout. The subtitles are much better than the old ffdshow.
http://ffdshow-tryout.sourceforge.net
VirtualDub : Fade in/out from/to white color
By lujmoarf in forum EditingReplies: 4Last Post: 21st Feb 2011, 21:13 -
FFDShow and vmr9 with overlay color controls no longer work. Please help
By mces97 in forum Software PlayingReplies: 0Last Post: 30th Jan 2011, 15:57 -
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 09:04 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 08:53 -
color tapes are showing as black and white
By mbermel88 in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2008, 15:04
