I simply want to take titles from a DVD and convert them to MPEG-2 files. How can I do this?
--Bruce
Results 1 to 11 of 11
Thanks for the link! That app would be perfect, except that the audio is not included in the resulting MPEG-2 file. Should it be?
--Bruce -
Actually, I do have audio if I play it only computer. I am missing audio, however, when I try to play it through my Happauge MediaMVP. GSpot reports that the audio is encoded using DOLBY_AC3, so I'm guessing the MediaMVP doesn't support this?
It doesn't look like VOB2MPG provides an option to encode using MPEG2_AUDIO. Is there another application I can use to convert the audio portion, or is there another DVD to MPEG2 converter that will give me what I want?
Bruce -
If you have dvdauthorgui , besweet and vobedit , then
Vobedit > Load first vob of title > demux > select all 3 options in lower panel (not the split) , and output to new folder .
Besweet installed , then rename ac3 to Audio.ac3 , and place on C:\
Go to where this audio file is now , then right click anywhere , and select "new text file" , now rename it convert.bat , answer yes to the file extention change , it must have BAT as the extension .
Right click this file , and choose edit , and copy this next lot of text into it , and save .
"C:\Program Files\Besweet\BeSweet.exe" -core( -input C:\Audio.ac3" -output "C:\Audio.MP2" ) -azid( -s stereo ) -2lame( -m s -b 192 -e ) -profile( ~~~~~ Default Profile ~~~~~ )
And let it rip , and wait till completed .
Rename the m2v video stream to video.m2v .
Move video.m2v and the new audio.mp2 to C:\Program Files\DVDAuthorGUI\bin
Reopen our convert.bat file , and replace the original text with this new lot , and save it .
mplex -f 8 -o final.mpg video.m2v audio.mp2
Move this edited bat file to C:\Program Files\DVDAuthorGUI\bin , and let it go .
Your mpeg is called "final" , and is found in C:\Program Files\DVDAuthorGUI\bin\ folder . -
Vob2Mpg does what you asked for, it does not Convert anything, just strips out the extra VOB information leaving the MPG files that the VOB contains.
The MPG files have AC-3 audio, as most DVDs will. Rather than lower quality and take a lot of time on every conversion, I would concentrate in either finding a way to make your chosen player able to play the higher-quality original sound without time-consuming conversion, or get another player. Most will handle AC-3 sound. -
Atleast I can still avoid .net framework 2 , and batch is much more fun when you know that the final file will be what you wanted in the first place .
Nelson37,
I understand what you are saying, but MediaMVP is not a DVD player per say, so it isn't a matter of finding another player. The device connects to your TV and pulls video content from the network. I could go on and on about the deficiencies of this product, but it is what it is, and I'm looking for a solution that will work with it.
--Bruce
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Super, mpeg2 16:9 to mpeg2 4:3 letterbox
By JN in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 02:35 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
Check the file with
