okay i just got the new Rogers webstar scientiffic-atlanta cable modem
i hooked it up and disabled my intergated network connection. and enabled the webstar modem
i dont even need the ethernet cord hooked up cuz it has a usb cord that is giving me connection (fire wire im guessing?)
so ive tried to get my computer upstairs to work with my old smc 7004vbr router
and it says on the green lite indicator that the computer upstairs has connection. but when i try to load a site up there it doesnt load.
the network connection says i have connection. yet the sites wont load at all..
ive played with the enthernet cords and the usb cord for hours and i still cannot get the computer upstairs internet to work
ive disabled and enabled both intergrated and webstar modem.
still not working for the other computer
any help please?
pic of my network settings
http://img.photobucket.com/albums/v137/NateDoGG/untitled.jpg
Unless I've misunderstood you, it sounds like you have the new modem connected to your pc via usb cable and the pc upstairs is connected to your old router!?
Your modem should be connected to the WAN port of your router, your pc's (both of them), then connect to the LAN ports of the router. The router routes(directs) traffic between the pc's and out to the internet.Google is your Friend -
Yes, the modem needs to be connected to the router. Otherwise the router serves no real purpose.
Router for USB Cell Modem
By Poppa_Meth in forum ComputerReplies: 3Last Post: 11th Jun 2009, 19:02 -
Which modem router to get?
By Tbag in forum ComputerReplies: 3Last Post: 1st Jun 2008, 16:54 -
using modem router whilst shut down
By Tbag in forum ComputerReplies: 2Last Post: 28th Sep 2007, 16:14 -
Connection problem with Asus router
By tweedledee in forum ComputerReplies: 23Last Post: 3rd Sep 2007, 22:07 -
DSL modem/router forwardports?
By mvp in forum Newbie / General discussionsReplies: 5Last Post: 27th Jul 2007, 14:52
