hi ,
I have a DVD9 in the HDD splited in 2 discs ,disc1 and disc2 ,and i want to convert them into one disc DVD5.«
If someone could help me ,i apreciate
Results 1 to 20 of 20
I love children, girl children... about 16-40
W.C. Fields -
You can join the main film with dvd shrink and then shrink it to one dvd, see https://forum.videohelp.com/viewtopic.php?t=284279
you could be a little more specified ,but thats okOriginally Posted by Baldrick
thanks -
https://www.videohelp.com/guides.php?guideid=538&howtoselect=6;30#538 from the link I just posted above...
thanksOriginally Posted by Baldrick
I had already read 2 guides
,none of them was this
(I repost to get notification )
I want to keep menus and all that .how can i do that?? -
Very hard - near impossible - using freeware, especially for someone as inexperienced as yourself. DVDRemake Pro can do it, but it costs money:
http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php -
simple and clean .
more simple than this will be hard to find .
i was thinking ,reauthored de DVD in DVDlab pro into one ,update the ifo with ifoupdate ,and they were ready to go -
Seems like a simple answer... Buy the original. Problem solved. Then again, in order to join a DVD-9 that is split on your hard drive, you already have the original, right?
Edit : after or before ,run DVDremake?
After. You have a 12+ GB file now. You have to get it down to less than about 8.5 GB for a dual layer DVD, or less than 4.37 GB for a single layer DVD. If you're planning on fitting the whole thing onto a DVD5, then you may not be too pleased with the results. -
see the picture above ,
*.VTS_02 are the extras ,director's coment ..VTS_03_0 has the menu of the second disc ,and i think i wont be able to play disc 2 ,
but refering to menu of disc 2 how can i delete it? -
It seems to me that what he has is a movie that is split across 2 DVD-9 discs that he wants to combine into one DVD-5 AND have the menu work. My suggestion would be to just shrink the 2 ripped DVDs to burn on 2 DVD-5 discs and be done with it. The process of trying to shrink and combine 2 separate DVD-9 discs is, in my opinion, more trouble than it's worth.Originally Posted by ybeard
Each disc has 6 Gb .
The quality of the main movie is on 30% ,and the menus are horrible .
you give me an idea ,i dont have subtitles to 1 disc have for 2 ,and 3 ,so i think i will do like you said.
thanks bro.
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 08:55 -
How do i convert an (ISO) dvd9 to a dvd5 and keep the menus???
By jcurrieirocz in forum Video ConversionReplies: 5Last Post: 26th May 2009, 09:15 -
how can i convert my dvd5 to dvd9
By scratchlikeme in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 21:54 -
Is there EZ way to convert DVD9 to Half-D1 DVD5 and keep all menus, etc.
By nwl in forum DVD RippingReplies: 3Last Post: 27th Jul 2008, 02:22 -
DVD9 To DVD5
By taylor6698 in forum DVD RippingReplies: 3Last Post: 22nd Oct 2007, 21:36
