when i get to the 2nd of 2 mpg files i am getting this error
Version: SVCD2DVD 2.1
Build: 2.1.2474.30185
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
anyone know the prob?? [/list]
Post your log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Yep - need more info... Logs files are kept in the "logs" folder under where you installed the program.Originally Posted by JikchungSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.1
Version: 2.1.2474.30185
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.86 MB
Executable size in bytes: 3006547
Executable CreationTime: 10/10/2006 16:57:38
Executable LastWriteTime: 16/04/2007 00:31:26
Executable LastAccessTime: 16/04/2007 19:55:00
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 0.99 GB
Free Physical Memory: 622 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.95 GB
***************************** Computer *****************************
Computer Manufacturer Name: VIA
Computer Model: K7VT6
System Type: X86-based PC
Computer Name: CHRIS
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: CHRIS\CJL
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 2800+
Description: x86 Family 6 Model 10 Stepping 0
CPU Speed: 2.082GHz
CPU FSB: 166MHz
L2 Cache Size: 512 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Processor: RADEON 9600 XT AGP (0x4152)
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 128 MB
Status: OK
Name: R9600XTurbo - Secondary
Mode:
Video Ram: 128 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 1.51 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="16/04/2007 20:55:13" Filename="NONE"><AssetSet><Asset ID="e144aeea-2c11-49ce-b5ee-2d8a88aec865" Path="C:\Documents and Settings\CJL\Desktop" Filename="rus-hills2ts200.mpg" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="rus-hills2ts200.mpg" AssetID="e144aeea-2c11-49ce-b5ee-2d8a88aec865" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NeroBurner" DVDDrive="PIONEER DVD-RW DVR-111D" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 690 MB
file=C:\Documents and Settings\CJL\Desktop\rus-hills2ts200.mpg
FormatName=mpeg
Num_Frames=61552
DurationInSecs=2462
Duration=00:41:02.0
VideoCodec=mpeg2video
Width=480
Height=576
Standard=PAL
BitRate=2352
AudioStreamCount=1
Audio1StreamID=[0x1c0]
Audio1SampleRate=44100
Audio1Codec=mp2
Audio1BitRate=224
Audio1Channels=2
Processing rus-hills2ts200.mpg
20:55:51: Done: Processing assets for DVD creation
Authoring DVD Folders
20:55:51: Creating TitleSet # 1
20:55:51: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
20:55:51: -->: DVDFolders creating VTS
20:55:51: -->: VTS 02
20:55:51:
DVD Folders: Processing C:\Documents and Settings\CJL\Desktop\rus-hills2ts200_S2D.mpg...
20:55:51: -
heres another from the same files
Width=480
Height=576
Standard=PAL
BitRate=2353
AudioStreamCount=1
Audio1Codec=mp2
Audio1BitRate=224
Audio1Channels=2
Processing rus-hills2ts100.mpg
10:14:39: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
10:14:39: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
10:14:39: libavutil version: 49.0.0
10:14:39: libavcodec version: 51.4.0
10:14:39: libavformat version: 50.2.1
10:14:39: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
10:14:39: Input #0, mpeg, from 'C:\Documents and Settings\CJL\Desktop\rus-hills2ts100.mpg':
10:14:39: Duration: 00:43:41.1, start: 0.746689, bitrate: 2353 kb/s
10:14:39: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 480x576, 2100 kb/s
10:14:39: Output #0, dvd, to 'C:\Documents and Settings\CJL\Desktop\rus-hills2ts100_S2D.mpg':
10:14:39: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 480x576, q=2-31, 2100 kb/s
10:14:39: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
10:14:39: Stream mapping:
10:14:39: Stream #0.0 -> #0.0
10:14:39: Stream #0.1 -> #0.1
10:15:39: error, non monotone timestamps 105026400 >= 105019200
10:15:39: [dvd @ 0069DF34]packet too large, ignoring buffer limits to mux it
10:15:57: error, non monotone timestamps 141422400 >= 141415200
10:15:57: [dvd @ 0069DF34]packet too large, ignoring buffer limits to mux it
10:16:36: error, non monotone timestamps 223822800 >= 223822800
10:16:36: [dvd @ 0069DF34]packet too large, ignoring buffer limits to mux it
10:16:41: video:672155kB audio:71663kB global headers:0kB muxing overhead 2.835682%
File Size: 690 MB
FormatName=mpeg
Num_Frames=61552
DurationInSecs=2462
Duration=00:41:02.0
Width=480
Height=576
Standard=PAL
BitRate=2352
AudioStreamCount=1
Audio1Codec=mp2
Audio1BitRate=224
Audio1Channels=2
10:17:01: Done: Processing assets for DVD creation
10:17:01: Creating TitleSet # 1
10:17:01: SVCD2DVD: DVDfolders
10:17:01: -->: DVDFolders creating VTS
10:17:01: -->: VTS 01
10:17:01:
DVD Folders: Processing C:\Documents and Settings\CJL\Desktop\rus-hills2ts100_S2D.mpg...
10:17:51:
10:17:52: -
Well i would need to see the whole log from the run in question to comment 100% but maybe this is the issue:
FreeSpace: 1.51 GBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Title: 2.1
Executable LastAccessTime: 17/04/2007 23:01:46
Version : 5.1.2600
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Free Physical Memory: 553 MB
CPU Speed: 2.082GHz
CPU FSB: 166MHz
Video Ram: 128 MB
Status: OK
Mode:
Video Ram: 128 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 3.49 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 7.39 GB
<SVCD2DVD DateTime="18/04/2007 00:05:33" Filename="NONE"><AssetSet><Asset ID="9f9c0e53-9d2e-4149-b4b2-aed163e9f98c" Path="C:\Documents and Settings\CJL\Desktop" Filename="rus-hills2ts100_S2D.mpg" /><Asset ID="aa019943-e36c-4342-aeff-ba8b268411e3" Path="C:\Documents and Settings\CJL\Desktop" Filename="AVSEQ01.MPG" /><Asset ID="10902c73-bda0-415c-84d3-58c0cad4f80a" Path="C:\Documents and Settings\CJL\Desktop" Filename="AVSEQ01.MPG" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="rus-hills2ts100_S2D.mpg" AssetID="9f9c0e53-9d2e-4149-b4b2-aed163e9f98c" MplexOffset="0" /><Title Name="AVSEQ01.MPG" AssetID="10902c73-bda0-415c-84d3-58c0cad4f80a" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NeroBurner" DVDDrive="PIONEER DVD-RW DVR-111D" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
File Size: 746 MB
file=C:\Documents and Settings\CJL\Desktop\rus-hills2ts100_S2D.mpg
FormatName=mpeg
Num_Frames=65519
DurationInSecs=2620
Duration=00:43:40.7
Width=480
Height=576
Standard=PAL
BitRate=2390
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=mp2
Audio1BitRate=224
Audio1Channels=2
00:05:33: Leaving rus-hills2ts100_S2D.mpg alone. File has Nav Packs
File Size: 690 MB
file=C:\Documents and Settings\CJL\Desktop\AVSEQ01.MPG
FormatName=mpeg
Num_Frames=61545
DurationInSecs=2461
Duration=00:41:01.8
Width=480
Height=576
Standard=PAL
BitRate=2352
AudioStreamCount=1
Audio1Codec=mp2
Audio1BitRate=224
Audio1Channels=2
Processing AVSEQ01.MPG
00:05:52: Done: Processing assets for DVD creation
00:05:52: Creating TitleSet # 1
00:05:52: SVCD2DVD: DVDfolders
00:05:52: -->: DVDFolders creating VTS
00:05:52: -->: VTS 01
00:05:52:
there ya go, am gettin a ffmpeg.exe error before i get the error mentioned earlier, it only seems to have the prob when doing the 2nd of the 2 mpegs -
I have sent you a link to v2.5 to see if the issue remains.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
