is it possible to run 2 copies at same time of this using the method below
https://www.videohelp.com/virtualdubframeserve.htm
Results 1 to 16 of 16
Possibly, go ahead and try it. But since encoding uses as much CPU power as possible or available, I would expect two encoders will run at half speed of one, so it would take you the about the same amount of time as doing it twice. Why not do a batch encode and run it all overnight? Then you could encode several files, one after the other.
Load the first movie, set up the encoding options, File->Save Project. Load the second movie, set up the encoder, File->Save Project.
Once you add all the movies you want, File->Batch Encode. Add the projects to the window, click Run. -
what even if files are in .vdr formatLoad the first movie, set up the encoding options, File->Save Project. Load the second movie, set up the encoder, File->Save Project.
https://www.videohelp.com/virtualdubframeserve.htm -
I have already ran 2 instances of VDub frameserver and now ended up with 2 .vdr files which I then put into TMPGEnc to encode these are 2 seperate movies I mean so what I am saying is now I have 2 movies which have been frameserved in VD as now .vdr can I now place both those into TMPGEnc to encode as 2 seperate movies
You have to run two instance of tmpgenc and two instances of virtualdub. If tmpgenc won't let you run two instances then you are in for a hard time.
If you don't have dual core or dual cpus then you are, in fact, more likely to less performance out of running two instances than running one instance and batching the jobs.Read my blog here.
Which version of tmpgenc ?
For tmpgenc plus, you can batch using this guide :
http://www.afterdawn.com/guides/archive/advanced_tmpgenc_guide_page_7.cfm
And for Tmpgenc Express 3.x, you can use this one :
http://www.afterdawn.com/guides/archive/advanced_tmpgenc_xpress_guide_page_6.cfmRead my blog here.
sorry I meant to say tmpgenc plus I have version 2.5 and can see where to encode batch lots as the files will b in .vdr extensions so will try that guide
well just now discovered u cannot add 2 .vdr files into TMPGEnc Plus only seperate
You can run two instances of Vdub Frameserving, and then either :
1. Run two seperate copies of TMPGENC and encode at the same time, or
2. Set up to batch encode as Abond described.
I have done it both ways.
Your explanation of what exactly you are trying to do and precisely what problem you are having is unclear. -
dam dam and treble dam so sorry all I must have missed abonds reply yes did it now as abond said went to batch encode and its encoding well 1st movie so hopefully it will carryone with 2nd when its finished many thanks again all
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
TMPGEnc author4 running codec twice
By BRck in forum Software PlayingReplies: 2Last Post: 4th Feb 2009, 07:47 -
bad copies
By freewave in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2009, 02:43 -
Copies Of DVD5's
By kpoman in forum DVD RippingReplies: 5Last Post: 23rd Oct 2008, 00:33 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 23:33
