I'm a recently registered user primarily interested in the DVD4 tool. I've been able to teach myself to use the tool successfully using the How-To and this forum. However more and more frequently, the conversion is failing due to bad frames being detected in the vob file created through MTR. Is their a way to repair or work around this? The file playback works fine. I'm also finding that MTR seems to have trouble ripping some of the newer movies I've bought. I've not been able to locate any updates. Any suggestions? Thx.
Hi MUSHROOM,
You may want to try MTR version 3.
I've been using it for a while but I cannot remember where I got it from.
Rio.
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
