i have a 1 dvd movie [.vob] which is about 3.65 gb,, nero told me that this file wont fit in.. but i thought it will fit in a 4.7 gb. DVD+R
why? any solution for this?
i use nero because its a friendsly user for creating menu, [movie clip]background and thumbnail buttons.![]()
try and try
Make sure that Nero is not re-encoding your files. It is notorious for this. Do you get the same error in other authoring programs? You might give TDA a try and see if it works.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Is the movie split into a number of vob's?Dvd vobs can only be 1gb in size.You should then have 4 vobs.3 1gb and 1 .65 gb in length.These are dvd specs.
bmiller,ont.canada -
i have merge the three vob's into one.. by using VobMerge
the three Vobs contains 1.3 each.
and the duration of that movie was two ours.
as Forum Troll said.. i can noticed that nero is also reencoding my video.. can i disable it?
i have to try as u recommened [TDA] il see if i like it..try and try -
Nero may be trying to re-encode the large vob into a single 1gb vob for a dvd.Not good.You need an authoring tool which will split the large vob up and add the associated files to make it a compliant dvd.
Use VOB2MPG to extract the mpeg video and appropriate audio streams, then use GUIForDVDAuthor to author the disc. There will be no re-encoding.
Read my blog here.
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 03:43
