here are the the details using mediainfo:
General #0
Format : AVI
Format/Family : RIFF
File size : 231 MiB
PlayTime : 43mn 4s
Bit rate : 743 Kbps
Video #0
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
Codec settings/Packe : No
Codec settings/BVOP : No
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 43mn 4s
Bit rate : 602 Kbps
Width : 704 pixels
Height : 400 pixels
Aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.071
Writing library : Lavc51.29.0
Audio #0
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
PlayTime : 43mn 4s
Bit rate : 128 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Resolution : 16 bits
Reindex it. Divfix++ should do it, or better yet (hee hee), make yourself a 5.1 soundtrack with the script: https://forum.videohelp.com/viewtopic.php?t=326127
That batch process will also unpack and reindex your AVI. -
Thanks Soopa...The 5.1 would be great but it is not crucial but I would love to know why my PC sees the widescreen 16x9 tag but the Philips Divx DVD player does not.
DivxFix did not help me....
Other ideas???
Y
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 07:02 -
TMPGenc CAN NOT CONVERT AVI LF RT CHANNELS TO 2 AUDIOS
By suijaypao in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 05:03 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 00:21 -
trying to convert AVI to DVD. mplex error. Cannot find .mpa file?
By anarchyx34 in forum ffmpegX general discussionReplies: 8Last Post: 14th Sep 2008, 19:14 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
