My pc is only starting in safe mode. It is Win98 , I ran scandisk and it said something about cross linked files. I read that I could use scanreg /restore and it may fix it, but it says I need to run it from dos and not a command window. I cant belive I am asking but how do I start in dos mode? Can I just use the restore disk? Also, if I need to try the restore disc I usually have two options 1. Restore Win98 will format and 2. Restore Win98 will not format. If I choose 2 I wont lose my stuff will I?
Shift+F5 = Boot to DOS prompt in Safe Mode.
Or, hold down the CTRL key during POST and select DOS mode.
As to saying you "need to run it [scanreg/restore] from dos . . . ", are you sure it isn't telling you to run SCANDISK from DOS mode at the C:\> prompt?
Connecting to the internet in safe mode
By hellfire45 in forum ComputerReplies: 0Last Post: 1st Dec 2010, 20:23 -
Cannot change resolution when in safe mode
By mysts in forum ComputerReplies: 5Last Post: 23rd Oct 2008, 13:24 -
WindowsXP is @#%ed - how to burn CD from safe mode?
By sdsumike619 in forum ComputerReplies: 7Last Post: 19th Oct 2008, 23:16 -
safe mode screen?
By alintatoc in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 17:27 -
help! i can only boot in safe mode
By ted demen in forum Newbie / General discussionsReplies: 30Last Post: 6th Jun 2007, 07:51
