On some of the dvd-r's I have been recording on, I will occasionally get an error message saying the disc needs cleaning or it may be damaged. Sometimes the discs will eventually work again if I try several times to load them, but some just won't. I have used Memorex, Fuji, TDK, Maxell and have had the same troubles with all. Is thsia common problem with theis model?
I called Toshiba and they're sending me a firmware update.
I also have D-4 never experience that but I used fairly decent disc panasonic & sony. I used only 4x. If they have a firmware then others must have complaint about same experience. I don't understand why they would let you download the firmware.....
The firmware update is for finalizing problems, unless there's a newer one. Sounds like you've got burner problems, or maybe a dirty lens.
Recording to RAW or -RW will work perfectly, it's only the -R's that sometimes will get the error.
I've got a D-R4 that does the same thing. The firmware update didn't fix it. The update is for finalization problems with 16x discs. There may be a newer update, I don't know.
toshiba sdp95swb
By paul72 in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2011, 05:51 -
toshiba sd2010
By kibz in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2010, 01:58 -
Toshiba RD-XV48DTKB
By GT40 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 08:36 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57
