I have a video clip, it says the format is also video clip, that I would like to seperate the audio from? Someone helpThanks
Try dropping it into Gspot, so you can see what the video and audio formats really are.
For AVI type formats, you could use VirtualDub Mod or similar and demux the audio to separate it from the video.
For MPEG type formats, there are several programs that can demux. I use TMPGEnc encoder for that most of the time, or try the freeware ProjectX.
And welcome to our forums.
If you just want the audio, you can record it with Audacity (freeware).
Start Audacity recording, then play the video clip. Set Audacity to "Stereo Mix" and it should work.
Seperating MKV 3D files
By Mike001 in forum EditingReplies: 1Last Post: 15th Oct 2011, 02:28 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23 -
Seperating Audio Channels.
By vodmare in forum AudioReplies: 7Last Post: 14th May 2007, 17:33
