Ok, I am trying to make a dvd from a mkv file what i do is extract the files with mkvextract , then convert them to dvd compliant files with tmpgenc 4.0 express and compile the dvd with dvd lab pro but when i try to watch the dvd the audio and subtitles are out of synch with the video, how can i fix this problem?
can't help with the sub-titles
but with sound
load the extracted avi and the extracted audio into avidemux
and play it, avidemux has the abilty to offset the sound from the video +- milliseconds, just adjust the numbers until the sound and video are in sync, then save the file, use the stream copy function so there is no encoding,
now demux the new file, and you are ready to start converting /authoring
didn't you or somebody just ask this exact same question in a another post
More problems with MKV files
By carlmart in forum Video ConversionReplies: 22Last Post: 19th Nov 2011, 21:28 -
Problems with mkv files
By Jdog in forum Video ConversionReplies: 0Last Post: 7th Aug 2010, 11:59 -
AVSconversion audio problems (mkv-dvd)
By VicSedition in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 15:29 -
WD TV, Audio problems on 1080 mkv files.
By gustav32 in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th May 2009, 13:28 -
(MKV) Audio/Video synching problems after remuxing the same files I demuxed
By Sigma X Virus in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2009, 16:27
