ClearVision Studios has just competed filming a new project that used the HD-SDI output on the Canon XL-H1 to capture uncompressed HD-SDI footage directly to hard drive in real-time using Premiere Pro 2.0. With chooses of lenses on the XL-H1 and HD-SDI output, the footage was amazing. One of the best parts was having the ability to feedback "instant dailies" to the set within seconds.
If you have worked on anything similar or plan too drop me a message.
Results 1 to 9 of 9
Michael Murphy
www.clearvisionstudios.com -
Was that a question or a promo?
The XL-H1 like other pro cameras outputs SDI (SMPTE-259M SD or 292M HD)
http://downloads.canon.com/cpr/software/video/XLH1_InputsOutputs.pdf
SD data rate would be ~270Mb/s SD or ~1485 Mb/s HD (~670GB/hr)
An HD SDI input/output card (see AJA or BlackMagic) and a large RAID would be required.
Monitoring is usually provided from the SDI card. -
Not a promo or a question. Just curious if anyone else is working with this technology. If so, I would love to chat and share notes!
We're using Black Magic cards and our capture machines use a very large RAID. 16 SATA II drives all striped together. Each machine has 8 TB of storage which in theory would give us about 12 hours of record time.Michael Murphy
I don't have that luxury but you can find many others with similar rigs in the post focused Premiere Pro and Canon XL forums.
http://www.kiva.org/about -
16 HDD's striped? Does that mean if 1 fails you lose everything?
That'd be scary -
They would usually configure as a fault tolerant RAID with hot swap drives.Originally Posted by KBeee
Here is an example of a medium-high level solution.
http://www.avid.com/products/videoRAID/
Here are some of the more affordable RAID solutions.
http://www.videoguys.com/storage.htm -
The drives are running a RAID 5 configuration. With that config, the drives still write about 400MB per second.
Michael Murphy
Each HD SDI feed is ~ 185MB/s so that covers you for realtime single channel read and write. Typical real time processing cards need 3 to 4 synch SDI feeds for A-Roll, B-Roll, overlay (or matte key) and record.Originally Posted by ClearVision
That is why these post production RAIDs get so huge.
Compression that use to work perfectly
By ckeen in forum Newbie / General discussionsReplies: 23Last Post: 3rd Apr 2012, 20:58 -
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 21:44 -
Feature Length Video Compression for DVD
By grebanahs in forum MacReplies: 4Last Post: 18th Sep 2010, 04:51 -
Bypassing compression
By michelp in forum EditingReplies: 5Last Post: 4th Aug 2008, 14:51 -
how do you work with HDV tapes?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 5th Dec 2007, 23:03
