Hi All
About 3 yrs years ago, I got into converting home videos to DVD after the birth of my first child. I was basically editing, adding music and some effects and then authoring. I was always a little disapointed ith the final outcome and over time i learnt that how you actual video makes a lot of diference to the quality.
3 years later I now have a second child and i was wondering if the technology has changed much and should I be using other software for a better outcome. In the past I used:
MovieMaker originally and then Adobe Premier Pro 1.5 to edit and add music etc...
I used TMPGENC to encode
I used TMPGENC DVD Author or Adobe Encore to create the DVD
Would anyone recommend a change in this given that 3 yrs has passed!!!
Results 1 to 1 of 1
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
old vs new technology - which is actually better?
By zieske in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 25th Mar 2009, 14:06 -
New BR technology we dont know about ?
By ian curtis in forum Software PlayingReplies: 6Last Post: 30th Jan 2009, 22:02 -
HD TV with laser technology
By Delta2 in forum Latest Video NewsReplies: 2Last Post: 30th Dec 2008, 00:21
