hello
in a website a video is offered in wmv and in mpg format
can you tell me please what the best quality?
if there is no fixed answer, how can I assess their quality after I download both?
thanks
Watch them . . . . . . ?
There is little in the way of imperical, qualitative comparison tools, especially across codecs. Whichever looks the best, when comparing web quality downloads, usually is the best.
If you are looking to do something with the videos afterwards, mpeg is often easier to work with.Read my blog here.
I was looking for a more 'accurate' way to determine which is best, than watching them...
Like guns1inger said, it's in the eye of the beholder. In my opinion, comparing specs in GSpot will tell you nothing. It's an apples and oranges comparison. At the end of the day it boils down to you having to watch both and see which you like better visually. The tools and techniques that went into encoding both files determined how they ended up looking. Guns1inger was also correct in what was mentioned about doing anything with it later. Stick to the MPG file.
Guns1inger is wise.
Well, you could do something statistical like PSNR measuring (which would work with ANY codec), but to do that correctly, you'd also need the original uncompressed source to use as a reference (then you'd be comparing good, bad and so-so apples to best apples). The MSU (russian) site has a PSNR comparison utility...
If you don't have the source file, you're better off comparing by eye. Then, to do it correctly, you'll have to train your eye to catch all the different types of "mistakes" and "cheats" that a codec makes. Could take a while and requires quite a bit of homework (like fully understanding the "Gibbs" phenomenon, an how different Q-tables affect the sharpness/smoothness regardless of the codec).
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
