Hi, my Media Player Classic refuses to play sound on wmv files. It gives me a "Media Player Classic could not render some of the pins in the graph, blah, blah, blah..." sort of message (if you want the whole message, let me know). Anyway, from what I gather, it needs an audio codec. I have had no luck with trying to find the correct codec. (I don't even really know what a codec is!) My MPC didn't used to have this problem, but it does now after my comp crashed and I had to reinstall EVERYTHING. Apparently whatever I had last time that made it work is not on my comp anymore. I had one or two codec packs back then, but I don't remember what they were. I also had WMP9 instead of 11. Other than that, my comp is back to the state it was in before it crashed. Is there any quick fix for my MPC issue? A simple codec pack or single codec I can dowload? A setting that needs tweaking? Anything?
I am on a WinXP. Be warned, I am a complete nube when it comes to video stuff.
Oh, and right now, I don't have ANY codecs installed. Are there any that I should really, really get, or should I just leave well enough alone?
I figured out the problem!! Since my comp crashed and had to be wiped clean, I lost all installed drivers. I was missing an audio driver, and MPC was compaining about it. Even though the speakers were plugged in, as far as the computer was concerned, it had no speakers.
[Ask] MPC Stopped Working At every start
By darkw1zard in forum Software PlayingReplies: 3Last Post: 28th Nov 2012, 09:06 -
No audio in MKV files when using MPC.
By ohnoeee in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2011, 03:04 -
Cyberlink filters for playback in MPC - not working
By menkatek in forum Newbie / General discussionsReplies: 1Last Post: 6th Apr 2011, 04:13 -
Subtitle not working in MPC HC
By majid_aryaee in forum SubtitleReplies: 6Last Post: 13th Oct 2010, 10:43 -
wmp11 & mpc-hc display audio info on the screen for mpg,avi files
By Danneauxsvh in forum Software PlayingReplies: 4Last Post: 6th Jun 2010, 12:16
