The thing is that I just saw a DVD movie in which the movie starts playing automatically without a menu, however it has chapters.
I would like to know if you know of a program that has that specific way of burning a movie?
Thank you for any information!
Results 1 to 11 of 11
I do it regularly with DVD Lab Pro when I am just testing encodes or specific filtering techniques.
ConvertXtoDVD creates this type of DVD by default.Read my blog here.
Thank You everyone for your responses and help!! I really appreciate it!
Originally Posted by GeorgeW
Hi George, the source video I'm using is .avi form, transfered from a camera via the 1394 connection. Before burning the movie usually I just make an intro and outro clip with Pinnacle Studio, and then I use this other program called MyDVD Deluxe and put them in their position with the unedited .avi portion of the video, and then burn it. There is a reason why I use Pinnacle Studio just to create clips, and MyDVD to burn the material.
Pinnacle Studio gets on my nerves because you have to add an icon for every chapter you make, having to make more menu template duplicates, compromising the memory on the DVD.
While MyDVD you have more flexibility to having just 1 menu template with 1 icon of the movie with all chapters in it......but even though it does that, it still doesn't get me to the point that I want. ...I hope I answered your questions correctly and didn't go off topic much.
Yes, that answers alot of questions. You appear to need an encoder (MyDVD is doing that for you at the moment). Unfortunately, I don't use MyDVD, so I'm not sure if it has the ability to play everything before menus (or even to create a DVD without menus).
I've used Ulead's DVD MovieFactory to do this -- it can create a DVD without menus, but maintain your chapter marks. So can DVD Architect 4 Studio, and I'm sure others as well. I mention these because they have a builtin encoder. Both have a free trial download.
There are also free encoders and authoring programs found in the tools section -- link on the left (some already mentioned by others in this thread).
Regards,
George -
Hey, Thank You for the info.
I'm going to try out some of the software and see which one convinces me more, again Thanks alot!!!!!!! -
Hi
I got the exact same problem in Pinnacle 12. Did you find a solution?
/Regards
Jorsan
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Newbie question: menu and chapters
By cheerful in forum Authoring (Blu-ray)Replies: 0Last Post: 19th Dec 2010, 23:17 -
Need more than 15 chapters on my menu
By Grunberg in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 07:17 -
DVD with no menu and just chapters
By marshyman in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 17:36 -
PAL to NTSC, Menu, Chapters
By heretic754 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2007, 13:46
