I'm using a litebox media hard drive, to store my movies and audio which I download off my pc. I can than play these through my TV and sound system. Problem is the litebox which supports mpeg-1,-2,-4, divx and xvid will not always recognise my files even though the same files can be played in Win Media Player 11.0 on my pc. I've tried a number of converters including 4U AVI MPEG converter but problem persists. Any ideas?
download gspot
and ckeck the info on those that play and those that don't
compare the info for the differences, could be the codec , the bit rate, or the frame rate
or the file might be mislabled
i have seen mkv files with avi ext, this can cause your problem
the same for a real media file ext rm or rmvb with the wrong ext the player on the PC might play them but your liteon will not -
Tanx for getting back. I've alresdy tried Gspot. When I run it on these files the default setting " enable interaction with codecs "becomes unticked and rendering is then disabled.
So I can't get any info on missing codecs, etc. Failing this would capturing by steaming on PC be a solution and if so, can you recommend program.
LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
By john8611 in forum DVD & Blu-ray WritersReplies: 11Last Post: 5th Feb 2012, 03:58 -
DVD player won't recognise hard drive
By Danny01boy in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2011, 21:43 -
Best portable hard drive
By danielmak in forum MacReplies: 3Last Post: 18th Sep 2010, 15:54 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Western Digital Portable Hard Drive question..
By Soccerman77 in forum ComputerReplies: 1Last Post: 9th Feb 2008, 02:29
